Projects 31 Chevy death trap
Discussion in 'Traditional Hot Rods' started by armymike, Mar 28, 2022.
  1. Stogy
    Stogy
    I don't see that with my phone upright...If I turn it I see that...yeah whatever...I think since this scrub issue was shared it should become a sensible item of conversation...we should strive for a better situation on our rides...this is truly not modern tech...this scrub stuff and furthermore hiems and tie rod ends and bolts all play a part...Gene mentioned the experience he had with it...its tech dammit!!!
    It's okay to be reactive a bit in my opinion...and I like to see what others have to say, heck it may save a life...
    VANDENPLAS, mad mikey and twenty8 like this.
  2. rustydusty
    rustydusty
    I actually didn't know the proper definition of "scrub line"
    Always learning something new on the HAMB!
  3. RMR&C
    RMR&C
    from NW Montana
    FWIW......I've built several hot rods with parallel leafs/beam axles. There are only a couple ways to lower them.
    1. Dropped axle. We see in this thread some of the drawbacks. Mainly scrub line, tie rod clearance, and braking lever effect. Scrub line issue may be overcome w/ taller wheels, but that negates much of the drop, IMO.
    2. Springs. Mono leaf, de-arched etc. This works, but only for a mild drop. Steering geometry may need to be changed to avoid bump steer.
    3. Axle on top of springs. This is the best I've found for a deep drop. A C notch is usually needed and you still need to watch the scrub line as the springs are now the lowest point. Steering geometry must also be corrected.
    TFoch, Stogy, WalkerMD and 1 other person like this.
  4. Hollywood-East
    Hollywood-East
    Gene, This...
    Is Exactly where the quote "A Wiseman, Is only a fool with a good memory" comes from! Well put Sir.
    Funny How wise I feel...
  5. 38Chevy454
    38Chevy454
    FWIW.....
    1. Any dropped axle (or dropped spindle) can have the same scrub line issues. Not isolated to just parallel leafs.
    2. & 3. Agree that any changes from stock height may need steering corrections for bump steer, geometry and clearance issues.
    4. (Added by me) a cross steering design is less susceptible to the bump steer issues, although it can still require some geometry or clearance adjustments for optimum steering and suspension travel.
    mad mikey, RMR&C, Stogy and 2 others like this.
  6. Ned Ludd
    Ned Ludd
    About braking lever effect: it's counterintuitive because those stretched axle ends feel spindly and springy, but I've done the math, and the torsion in a dropped axle beam is actually less than in a stock axle. The position of the spindle will throw you out, but it's irrelevant. The net lever arm length at work is the vertical distance between the tyre contact patch and the cross-sectional area centroid of the axle beam, which is shorter on a dropped axle given the same tyre diameter.
  7. TFoch
    TFoch
    Scary stuff!
    Stogy likes this.
  8. At least this vehicle is not running
    In or around the commonwealth LOL
    VANDENPLAS and Stogy like this.
  9. Stogy
    Stogy
    That's great Rusty, me as well, as I mentioned earlier at a minimum the images provided help educate us here building Hotrods and Customs and it makes for great discussion with the images certainly highlighting some of the problems that can arise lowering a vehicle...
    It also highlights not everyone understands ch***is fundamentals...and if you want to attempt it do your research...
    A shout out to Hambers is there anyone out there with a Hamb Friendly Hotrod with similar, year, stance with parallel leaf and beam with pics of how they overcome this?
    mad mikey and TFoch like this.
  10. badshifter
    badshifter
    A larger diameter rim (way off topic) and a short side wall tire would solve the scrub line issue, and ONLY the scrub line issue. The bolt, and all the other suspect work is just piling on.
    I believe if you start a thread with “Death Trap” in it, you are not scared away by the responses, nor are you interested In a fix, nor are you debating the laws and merit of Canadas vehicle code or the stylistic virtues of dropped Chevy axles or lack thereof. You are merely pointing out **** work. So to the op I say, well done. ​
  11. pprather
    pprather
  12. INVISIBLEKID
    INVISIBLEKID
    from Gilroy,CA
  13. INVISIBLEKID
    INVISIBLEKID
    from Gilroy,CA
  14. Stogy
    Stogy
    We are supposed to be a vintage Hotrod/Custom site...Large rubberband rim **** has already been shared and executed thankfully...that is not what I'm asking
    I'm asking of those in the know for a Hamb Friendly fix for what we are looking at while maintaining a similar stance and to me it involves an axle change, with a taller tire combined with a spring perch adjustment.It almost looks as if it's to low as it is now.
    If the OPster was highlighting a butcher job so why not show us what he did to remedy it...not everyone here is fluent in such things...maybe your right he's good with it who knows...
    This is why I asked our Ch***is Trained members to chime in and expand on righting what is something anybody buying or building may encounter...
    I'd also like to point out that axle being used is I believe a Ford axle as Chev axles don't share that constant 'I' rib in the OP
  15. Stogy
    Stogy
    RICH B and pprather like this.
  16. spanners
    spanners
    I'll be the one game enough to say "that much rake looks ****house". It looks like the front end has already collapsed.
    mad mikey, Maicobreako, RMR&C and 2 others like this.
  17. Chili Phil
    Chili Phil
    So many posts. The obvious answer is strip all that **** off and start over. A perfect example of trying to polish a turd.
    mad mikey and Stogy like this.
  18. Chili Phil
    Chili Phil
    I just noticed that this is in the Traditional HotRod forum. I must have missed the traditional part. Geeze.
    Stogy likes this.
  19. Stogy
    Stogy
    Noted...goodbye...;)...moral of the story...don't do this...:oops:
  20. A great example of how a Ford transverse leaf spring crossmember and front end setup would make a Chevy sit better and drive better
    Lloyd's paint & glass likes this.
  21. upspirate
    upspirate
    Nobody has mentioned that this is April 1st!!!!!
    alanp561 and Stogy like this.
  22. sloppy jalopies
    sloppy jalopies
    that is friday...
    Stogy likes this.
  23. twenty8
    twenty8
    The whole concept of April Fools Day is a joke.........:confused:o_O:rolleyes:
  24. Stogy
    Stogy
    Thread was posted on Monday 28 March...and the pics are apparently real in my opinion...I don't think anyone would have done that for a joke...Keep your eyes on the road your hands upon the Wheel I say...;)
    As Chili and others have said it needs a purge and reconfiguration by someone that gets it...
    armymike, Ned Ludd, TFoch and 2 others like this.
  25. Stogy
    Stogy
    Literally it's easy to get caught up in one...:D...but I don't believe this was a joke nor a sensible Hamber...
    upspirate likes this.
  26. upspirate
    upspirate
    Posted early!:p:D:rolleyes:
    Stogy likes this.
  27. upspirate
    upspirate
    And I agree, bad tech/design
  28. Don’t upset Stogy- he is one of the hardest working hambers out there.
    Max Gearhead and Stogy like this.
  29. Stogy
    Stogy
    Thanks Daylate...Threads like this are frustrating...but I thought there was some positive discussion out of it all...and again this fella never come across as this type in the few other posts he made...somewhat strange frankly...I'm surprised nobody knows of this truck or Hamber in California...someone mentioned the Wagon, it is a strange model as that rear side door is extra wide...what is it ?
    I note 'Cali' Dream'n and Californian's largely hate that slang...ask me how I know...
  30. Yeah. Hard to tell if it is legit or not. Some days I have patience for it, some days not so much. You do a lot of digging, and it is appreciated, at least by me.
    Stogy likes this.
