Technical 31 coupe trunk latch , bear claw
Discussion in 'The Hokey Ass Message Board' started by Wesley Laster, Apr 5, 2020.
  1. Wesley Laster
    Wesley Laster
    So the doors are done on the coupe. So it was time to do the trunk .
    Now the trunk was a rumble seat lid that was in poor condition, and then it was reskinned by someone ..... with that said , I plan on replacing it all together, but for the the meantime, I need a latch and a handle..
    I wasn't concerned with the appearance of the outcome . 20200404_105540.jpg 20200404_105545.jpg
  2. Wesley Laster
    Wesley Laster
    Here is the the latch ***embly I got off ebay for around $12 . The handle I had left over from another model a I had. .
    I went over several approaches , and decided I should have got a different latch.. but , oh well
    I decided to make a little box for the latch and then weld that to the deck lid 20200404_115048.jpg 20200404_115055.jpg 20200404_105532.jpg
  3. Wesley Laster
    Wesley Laster
    How I made the box 20200404_124622.jpg 20200404_133324.jpg 20200404_133321.jpg 20200404_131002.jpg
  4. Wesley Laster
    Wesley Laster
  5. Wesley Laster
    Wesley Laster
    The square tubing I used was 2"x 1" x .065 thick( 16ga i think....
  6. Wesley Laster
    Wesley Laster
    Now time to install the box I made into the trunk lid... the lid was heavily covered in bondo and little attention was payed to the rusty/ thin metal ... so wish me luck ... lmao... 20200404_164436.jpg 20200404_165030.jpg 20200404_170027.jpg 20200404_173113.jpg 20200404_184600.jpg
    akoutlaw likes this.
  7. Wesley Laster
    Wesley Laster
    I took more pictures but for some reason I cant find them ... ??? .
    I weled on a thin strip of flat stock to help reinforce the latch area .
    I had aslo drilled a hole a for the handle, prior to making all this and but then noticed it would interfere with the latch . So I drilled a second hole ...
    All that's left now is to figure out the handle to latch linkage and install the striker on the ch***is...
    woodsnwater likes this.
