Projects 31 Model A pickup (re) Build
Discussion in 'The Hokey Ass Message Board' started by scott mckelvey, Feb 19, 2011.
  1. ScooterCO
    ScooterCO
    from Parker, CO
    Looks Great! Well done.
  2. scott mckelvey
    scott mckelvey
    from Towson, MD
    Ill spare y'all of all the details of the issues of the initial firing and road test. but there were many a battle tooth and nail. After a week of chipping away I'm finally winning. And holy cow is this thing turning a riot to drive. This might actually work..... Bear in mind I did drove this truck the 20 miles home when I bought it, but barely. It ran like ****, overheated many times (it was like 30deg out), barely stopped, and didn't shift out of 2nd. I hoped much of it was repairable but wasn't sure
    Commuted one day to downtown to work. Did my first hiway runs tonight. The kid approves too....
    Still a lot of loose ends and some big things to finish. Interior, top, bed liner, e brake to name a few. And my heater core was leaking all over the inside. Any suggestions on economical way to get this remedied?
    I have a new problem though. Keeping fuel in it and back tires on it is going to be tuff.
    That said I read so much **** about the trans, I was pretty worried. Aside from weight and size and the whole "hotrods need 3 pedals" thing, I'm impressed. This is a full on pickup after all. Shifts smooth and good, but strongly. Don't sleep on these things.
    Last thought is I have a new appreciation for how tiny it is, when compared to my compact pickup ideal for city use.
  3. Hotrodmyk
    Hotrodmyk
    Nice truck, well done!
  4. Grudge
    Grudge
    So cool, congratulations.
    Aaron
  5. ty johnson
    ty johnson
  6. scott mckelvey
    scott mckelvey
    from Towson, MD
    -cleaned up and stained some of the wood in the roof.
    -first wash and wax
    -sprung ring pulls in the two access panels
  7. 1931fordtruck
    1931fordtruck
    That's sharp looking. Awesome job. Are you going to put a cover of some sort over the hole in the roof?
  8. mndodge
    mndodge
    Great looking truck...... You"ve brought it a long ways and will for sure get the "LOOKS" cause you hit it dead on!!
  9. Kess
    Kess
    from PA
    Very nice truck! Very cool!
  10. scott mckelvey
    scott mckelvey
    from Towson, MD
    the plan is for a removable cover. Planning on using slotted rail up front (like jeep or early bronco soft tops) to keep the wind/weather out.
    Thanks all. I'm pretty stoked with how things are turning out.
  11. scott mckelvey
    scott mckelvey
    from Towson, MD
    Got the bed lined. Roof wood back in. Fixed my door latch problem (see recent thread by me). And got the trans dust covers installed (thanks hamb cl***ifieds). Small stainless bracket to support fuel filler. T******* interior panels fo upholstery. List getting shorter.
    Driving is great at this point. Running good. Rattles gone. Tracks straight. Folks. No bump steer or suspension issues. Been cruising the beltway like it was made for it
  12. flatheadz-forever
    flatheadz-forever
    from new jersey
  13. Rpmrex
    Rpmrex
    from Indiana
    Wow! From where you started to where you are now! Looks like your plan was great and worked out great!
    Thanks for posting pictures and keeping us out here updated.
  14. scott mckelvey
    scott mckelvey
    from Towson, MD
    Getting a little interior done.
    Not intended to be fancy or anything. Although one bummer is I shopped for quite some time to get "sewn" pleated vinyl. Not sure how I messed up the order but I got welded vinyl. So, that's what the car is getting......
    I am wondering how long the white will actually stay white. I contemplated other colors but couldnt envision anything else.
  15. scott mckelvey
    scott mckelvey
    from Towson, MD
    By no means professional, or plush, but space was at a premium. Interior done. Havent touched a sewing machine in at least 20 years.
    Also mounted e-brake. I deliberated for months about position and really didn't want to cut a hole in my freshly painted cab.... Seat decisions were also hinged.
    Redid trans tv cable which was a nightmare.
    Did some errands today.
    Next up is a cover for the top, then some odds and ends.
  16. scott mckelvey
    scott mckelvey
    from Towson, MD
  17. VoodooTwin
    VoodooTwin
    from Noo Yawk
    I love your truck!
  18. Grudge
    Grudge
    X2
    Inspiring for my build, I hope it turns out as nice as yours.
    Aaron
  19. scott mckelvey
    scott mckelvey
    from Towson, MD
    thanks guys.
    aaron, absolute non sense. i've been following your build and it's plenty nice. tons of great details.
  20. scott mckelvey
    scott mckelvey
    from Towson, MD
    Revival!
  21. dirtracer06
    dirtracer06
    This is awesome....cant believe the transformation...very nicely done.
  22. scott mckelvey
    scott mckelvey
    from Towson, MD
    Trj revival came and went. It was in my backyard and I made Thursday night, Friday run, and Sunday. But I missed Saturday (sounds like biggest day by far) because of some familial stuff. Truck has been good and without issue in the interim.
    Replaced lost dipstick (don't ask).
    Work resumes.
    Bought some exhaust tubes and baffles from Matt at gear drive since he was at the show and I figured I was saving on shipping. That will be yet to come.
    Started on the top. Cut plain vinyl (inside) and more of the same pleated vinyl for the top. Glued together then Sewed on edging. Leading edge will be an awning/marine type slide in rail to keep elements out. The corresponding welt will need to be sewn in by someone w/ industrial machine. The rest will be snaps with Velcro strips to keep reasonable seal.
  23. scott mckelvey
    scott mckelvey
    from Towson, MD
    Ended up having my heater core recored. I gambled on an off the shelf model that was an rch too tall. Oh well. Its in and not leaking. Yay.
    Dropped the sewn roof cover off at upholsterers to sew in vinyl welt for front (too heavy for my machine). Then I can get the top done (although I hate the thought of drilling all those holes in my sheetmetal for snaps)
    Finished some carpet. I knew when doing the floors it would be problematic for carpet, but it was necessary for structure and space in my opinion. Ain't perfect but I'm very happy with it, but I've had my fill of sewing for the year.
    Took a little road trip to the last amca swap of the year. Swap was kind of a bust but Truck did great on both hiway and back roads.
  24. 26 T Ford RPU
    26 T Ford RPU
    Nice job on bringing it back, that truck will love you for it. JW
  25. scott mckelvey
    scott mckelvey
    from Towson, MD
    Exhaust was always on the long list. But I never really had any ideas that would work with susp and such that really spoke to me . Lake style headers (like 32 grills on A's, no offense to anyone) just seemed so p***e. I liked the manifolds and they were probably the best option for fit. but I never felt the cherry bombs
    P*** side tubing front section hung a little lower than my eye liked, but there's really no other way to route it because of starter and oil filter.
    At the trj revival Matt from gear drive had a trailer full of stuff so I got a pretty good deal on on a set of his chrome driveshaft tube style megaphones and baffles.
    The megaphones fit real nice in place of the cherry bombs. Still have to weld them up, but this it what it will look like. And as an added bonus I lose the big old mounts in favor of little rubber ones under the cab.
  26. scott mckelvey
    scott mckelvey
    from Towson, MD
    Started affixing the top. Pained me to drill snap holes in the cab, but I went excrutiatungly slow to avoid mistakes.
    Still have the sides and center ribs to do. Plus get stainless screws for front edging,as well as Velcro to help seal between snaps.
  27. Gas_Tires_Oil
    Gas_Tires_Oil
    Gorgeous Truck. Awesome save and redo. Hats off to ya!
  28. scott mckelvey
    scott mckelvey
    from Towson, MD
    Nothing really picture worthy. But a couple updates.
    Wrapped up everything for Small road trip to Jalopyrama a few weeks ago. Lost a hubcap on the way: Baltimore's streets are horrendous. Truck did well but seemed like it was pinging a bit cruising around 40-60 with virtually no load, but never under acceleration (or deceleration) like i'd expect from timing. Plus I know timing and dwell are dead on. Also had a little roughness off idle until I gave it some go juice.
    Understanding carbs but not well versed in strombergs, I did some reading. Based on what I read it seems like power valves were ample but jets were probably a little lean, which I knew might be case when making swap initially. So I upped the jets from 45 to 48, but haven't driven it yet. I was pleased too find that I could change them without removing carbs. One other note is that was first drive after swapping gl*** packs for Matt's open (baffled but unpacked) 35-36 driveshaft style megaphones. so its possible I created that probelm because they opened the exhaust just enough to lean it out a hair.
    Also been tinkering with brakes. They worked but just weren't "right", despite repeated bleeding etc. By accident I noticed a bad rear residual pressure valve (speedway), the checked front which was even worse. Replaced those with wilwoods, and bled tonight. pedal feels 100 times better. Tomorrow a test drive will tell. Also tested a new bleeding method tonight; loved it. More info here http://www.jalopyjournal.com/forum/showthread.php?t=378639
  29. scott mckelvey
    scott mckelvey
    from Towson, MD
    Still wasn't stoked on brakes. Tore some stuff apart and shoes were basically new and definitely weren't contacting drum well. Drums showed no real cause for concern. And I did find one side of rear had front and rear shoes reversed. Couldn't find anyone local that could arc shoes and could turn the front ford drums. So I took the time to get the shoes to fit by hand. Used adhesive backed sand paper on drums and did shoes until they fit each drum then readjusted. Very pleased. I'm DONE messing with the brakes now.
    Lost a hubcap on the way to jalopyrama and I'm kinda liking it. Thinking about spider caps or nothing at all, now.
    Any errand that requires driving I now volunteer to do. Each drive getting better and better. This thing is just silly to drive.
    Let my neighbor take it out today (car guy so I felt comfortable). I had a smile ear to ear getting to see car rolling in third person. and better yet was he was way more stoked than me, and very complimentary about performance.
  30. Leon Sandcastle
    Leon Sandcastle
    Spider caps would look good.
