Hot Rods 31 Model A Victoria Build w/Pics - Miss Vicky
Discussion in 'The Hokey Ass Message Board' started by D-Russ, Jul 6, 2008.
  1. sidevalve8ba
    sidevalve8ba
    Dave,
    It sounds great. I know you are excited about the prospects of getting it on the road in the not too distant future.
    By the way, what color of blue is that on the frame?
    Ted
  2. D-Russ
    D-Russ
    I'm getting pretty amped up about it. :D Wanna share the pics and video you shot?
    You know it man. It will have been off the road for two years next month.
    NEVER take your only hot rod off the road. NEVER.
  3. D-Russ
    D-Russ
    Thanks Ted. OJ got it running just right.
    The blue is a 1959 Austin Healey color – Ocean Blue. The body color is the same.
  4. MP&C
    MP&C
    Sounding good Dave, nice work OJ!
    D-Russ likes this.
  5. 57Trucker
    57Trucker
    Congrats Dave. It won't be long.
    D-Russ likes this.
  6. Martin_F
    Martin_F
    D-Russ likes this.
  7. D-Russ
    D-Russ
  8. ALEISTER
    ALEISTER
    Awesome, Dave! Where's the video of your test drive sitting on a bucket? I know you wanted to!
    D-Russ likes this.
  9. walter
    walter
    Great Job!!!!!!!!!!!!
    D-Russ likes this.
  10. Martin_F
    Martin_F
    Is this what you're talking about?
    daddio211 and D-Russ like this.
  11. Just Gary
    Just Gary
    Truth.
    And its corollary; NEVER sell a finished hot rod until its replacement is finished. :oops:
  12. langy
    langy
    Loving the build pics, looks real good
    D-Russ likes this.
  13. D-Russ
    D-Russ
    I'm not sure it would be a good idea to drive it with no steering, no brakes and no clutch, but I'll give it some thought, Mark.
    Yes Martin, that's very helpful.
  14. scottb356
    scottb356
  15. loudbang
    Like they say on America's funniest home video. Hold the camera "SIDE TO SIDE TO MAKE IT WIDE."
    D-Russ likes this.
  16. D-Russ
    D-Russ
    When I first started the new motor with the clutch and bell housing installed for the first time last weekend, there was interference between the bell housing and the flywheel. You can hear it in the videos that Martin shared in post 1003. After running for 30 seconds, it quieted down, so the flywheel teeth obviously "machined" the bell. Today I pulled the exhaust, drive shaft and transmission so I could remove the bell housing and inspect the interference area. It wasn't bad, but it wasn't good either.
    I broke out the dremel and did some more clearancing just to make sure there was no more contact.
    I put it all back together, fired it up, and I'm happy to report that my interference problem has been corrected.
    The flywheel was not hurt because the bell housing is cast aluminum. It would have been very bad if I was running a steel or cast iron bell. So those of you that are planning to run a Hot Heads Chrysler to Chevy flywheel, it will hit a stock Chevy bell housing without minor machining/clearancing in the inside bottom from the middle to the left side.
    I also bent up a simple battery hold-down strap.
    Studebakermatt and Martin_F like this.
  17. 57 HEAP
    57 HEAP
    Perhaps the crank centerline doesn't agree with the center of the bellhousing. Offset dowels are the answer.
    D-Russ likes this.
  18. D-Russ
    D-Russ
    Thanks Sam, that's what a talented machinist like yourself would do to fix the problem.
    Hacks like me just break out the ol' grinder. ;)
  19. D-Russ
    D-Russ
    First time on the ground with the new drive train. I think it may sit a little lower in the front with the hemi.
  20. MP&C
    MP&C
    Looks like something's sprung a leak. That right there's alcohol abuse... :p
    Congrats on another milestone Dave!
    loudbang and D-Russ like this.
  21. norms30a
    norms30a
    Really nice, tons of detail and great ideas.
    D-Russ likes this.
  22. D-Russ
    D-Russ
    I had a few buddies stop by yesterday to help me put the body on the frame for the last time. The deed is done.
  23. brady1929
    brady1929
    Wow, very nice.
    D-Russ and Studebakermatt like this.
  24. Mr48chev
    That car just looks better all the time. It keeps me thinking 32 frame rather than full fenders and stock (modified) for mine..
    D-Russ likes this.
  25. hotrodA
    hotrodA
    That's a big milestone. Congratulations!
    D-Russ likes this.
  26. MP&C
    MP&C
    Beautimous!
    D-Russ likes this.
  27. 57Trucker
    57Trucker
    Sweet! That thing is mink.
    D-Russ likes this.
  28. flthd31
    flthd31
    I have to chuckle every I check on your build. I've been following it all these years. I started a build in 2008 on a quite similar path of starting with swap meet junk body pieces, fabricating, ***embling, driving, tear-down and finish...it takes a long time. What's weird is how we have been p***ing similar milestones all thru the years. I dropped my painted and buffed body on the frame two weeks ago. It's been fun to follow along with someone that works at my pace...awesome build, thanks for all the posts.
    D-Russ likes this.
  29. K13
    K13
    Wow looking great Dave!
    D-Russ likes this.
  30. D-Russ
    D-Russ
    I'm a big fan of Model As on deuce rails – I just really like the look. And the added wheelbase doesn't hurt either. I'd say go for it (32 rails that is). If I were to run fenders, I'd run 32 fenders as well because they'll already fit the frame/wheelbase. Just need to fit the rear fenders to the wheel wells.
    Wow, thanks man, but other than the length of time we've been building our cars, there's really no comparison – you can fab/build circles around me. I mean that frame you built is ridiculous, but I appreciate the kind words.
