31 on duece rails progress
Discussion in 'The Hokey Ass Message Board' started by fatabone, Mar 9, 2005.
  1. fatabone
    fatabone
    Brought the body home to get ready for paint. Went by Clarks to check out the ch***is and its looking sweet. He is just about ready to finish the exhaust and setting up the rear. Mikey sent the engine to the machine shop so hopefully it will all be together in the next couple of weeks. I'm so excited had to post pics!
    Jr.
  2. AHotRod
    AHotRod
    Ahhhhhhhh, I'm not the only one building a trailing-arm rear suspension.....the project is coming along nicely.
  3. What's with the 'pro-street rearend treatment? BIG slicks down back?
    Looks pretty none the less.
    Cheers,
    Drewfus:)
  4. fatabone
    fatabone
    No slicks. The frame is modified to fit the A body.
  5. fatabone
    fatabone
    Definitely not Pro-Street
  6. Boones
    Boones
    from Kent, Wa
    what are you using for the rear trailing arms. ?? Did you make your own headers?
  7. fatabone
    fatabone
    I-beam for trailing arms and headers from T-man.
  8. Spike!
    Spike!
    Junior- That thing is looking sweet! I took a few more pics of it when I was at Clark's last weekend. Those Deuce rails and the new stance make it look sooo much better. Hard to belive it was the same little "A" that Duck had to push from the mud at the first Jalopy showdown. You gonna be ready for this years mud slinging?
    Spike
  9. FORDY 6
    FORDY 6
    Lookin' good, any side shots with the body on the frame?
  10. fatabone
    fatabone
    It'll be ready for the Showdown. Here is a side shot.
  11. av8jon
    av8jon
    Hey, really good progress and looking good!! Thanks for sharing the pics!
    Good luck,
  12. Clark
    Clark
    Boones ...the trailing arms are made of 2 1/2 I beam.
    Drewfus...the "prostreet" look is to get the rails behind the wheelwells. Otherwise we would have had to cut half the wheelwell out.
    Jr...your shop looks nice now!
    Clark
  13. Short-Stack
    Short-Stack
    looking good.....you might want to check the toe in though.
  14. kustombuilder
    kustombuilder
    from Novi, MI
    nice. i like what Clark did with the rear suspension. those I-beams look cool.
  15. Dan
    Dan
    the I-beams are cool, what did you use to attach them to the rear and what are you using for bushings in the front? Nice work...
  16. Imwalkin
    Imwalkin
    from Tucson, Az
    what everybody else said! the rear trailing arm are too cool cane we get more info more pics.
  17. biscuit
    biscuit
    That's a really nice looking rod fatabone. Good pics too. Good luck and I hope to see more.
    Biscuit
  18. Clark
    Clark
    The I beams have eurethane leaf spring bushings from a jeep. The cool part is I got 6 pair of them on Ebay for $60. I used to use Chevy truck trailing arm bushings but they would cost about $50 a pair.
    I'm working on a tech post for the rear suspension. It may take a little time so be patient.
    Clark
