Projects 31 tudor side glass options
Discussion in 'Traditional Hot Rods' started by coody, Jan 12, 2025.
  1. coody
    coody
    I had to mini-tub my sedan & now am seeing that the gl*** will not go all the way down. Thinking can you install the side gl*** like the rear gl*** is installed? My gas tank & battery is were the back seat was and will not be used for much of anything else. I am installing a sliding soft top and really wouldn't care if the side windows work or not. tks in advance!!coody
  2. rdscotty
    rdscotty
    from red deer
    I don't have a Model A, so don't know how the rear gl*** is installed. My first thought is, is everything there? Roll the window up and leave it up.
    coody likes this.
  3. Model A Gomez
    Model A Gomez
    The stock rear windows in a Model A Tudor didn't roll all the way down due to the wheel well, they kept the gl*** from going down much more than about 1/2 way. I'd install the gl*** where it will roll down part way for ventilation if nothing else.
    coody and hotrodjack33 like this.
  4. wuga
    wuga
    First off, if your top is chopped, do not cut the gl***. It will work just fine in both the doors and in the back sides. I installed a small actuator to the rear window. Being able to open that window made all the difference in the world.
    Warren
    Deutscher and coody like this.
  5. hotrodjack33
    hotrodjack33
    I agree. It's been 40 years since I've had a '30-'31 Tudor but, I recall that the back windows only rolled halfway down.
    coody likes this.
  6. lostone
    lostone
    from kansas
    I've been going through this in my head many times while building my 31 Tudor.
    So far it's been going the stock route, with the top chopped 3" this is probably the easiest. Option 2- split the side windows into 2 pieces and make the rear section of the side gl*** just slide straight forward. This would be the simplest as in there wouldn't be any regulators etc. In this scenario looking at the construction of a rear sliding gl*** truck window and /or maybe using the tracks from one would make it easier to build.
    And last but not least, urethaneing the side gl*** in place and make the rear gl*** go up and down. I do like this idea as it could be down with a switch on the dash. But I haven't found enough examples to get an idea on how to build it and making it water proof enough not to harm the interior. And yes I plan on having a back seat, gotta have somewhere to set the grandkids!!
    coody likes this.
  7. coody
    coody
    hey guys! thanks for all the replies! it never had gl*** in it when i bought it, thinking of installing the gl*** and leave it alone. I have the felt channel & upper seal. I do need a contact for the gl*** if someone has a supplier.tks
  8. Grumpy ole A
    Grumpy ole A
    There is a rear window roll down kit for a coupe. Can you modify it to work on your rear window?
  9. pprather
    pprather
    You should be able to find a local gl*** shop that could fabricate flat, safety plate, gl*** based on your pattern.
    5window likes this.
  10. RodStRace
    RodStRace
    I'll mention something else. On 4 door cars it sometimes helps to crack the rear window when the front is down for buffeting. I have never owned an A, so I don't know if this is true on this body. If you have the stuff, I'd suggest trying to make it work.
  11. pprather
    pprather
    On my non air conditioned '31 Victoria, we would open the windshield and roll those rear side windows part way down, to get air flow on hot summer days.
    That rod had 140k+ miles when I sold it.
