Technical 312 Y-Block Mods
Discussion in 'The Hokey Ass Message Board' started by fijidad, Jun 9, 2022.
  1. fijidad
    fijidad
    Getting to re***emble my '56 Ford Thunderbird and now I'm wondering if I outsmarted myself.
    Had the 312 Y-Block rebuilt, but wanted a bigger cam, so the rebuilder installed a cam from a '57.
    The '56 has a "teapot" carburetor and a non-vacuum distributor.
    Anyone have advice on how to set this up? I want to retain the '56 distributor as it has the tach drive gear. Am I screwed?
  2. dana barlow
    dana barlow
    from Miami Fla.
    Fords factory 57 cam works fine,but to get full benafeit *from it,you also need factory higher lift rockers* Ford designed to go with{1957 only rockers}.
    The teapot works{ I never have liked the teapot}, I like later Ford 4bbl better,it is higher CFM .there aftermarket plates to mount bigger base carbs on with.
    As for timing,with out the newer dizzy with sintrifcel.
    I guess you could set timing by looking at what it is doing with a dial light,from about 2000 up/an set so your getting max about 36* before TDC {give or take 1 *for best run.
    ekimneirbo likes this.
  3. miker98038
    miker98038
    I don’t get a “non- va***n” distributor, unless you’ve got an aftermarket with centrifugal and the tach drive and no vacuum can. Put up a picture. If it’s the original 56, it should have the dual vacuum can. 55’s used the single can, and 57 went to the centrifugal with a vacuum can. Trying to run with no “mechanical” advance will result in very poor performances.
    I’ve run the oem 55, keeping the tach drive and using an MSD timing computer. It works, but it’s not an optimal solution.
    Dana’s right about total timing. With the 57 up distributor 8-10 initial and 36 total is a good starting point.
  4. guthriesmith
    guthriesmith
    I run 57 4-barrel intakes and newer square bore carburetors which necessitates a 57 or newer distributor as well. Easier to deal with in my opinion that the teapot and ***ociated distributor.
    Boneyard51 and warbird1 like this.
  5. sunbeam
    sunbeam
    If you want to wake it up use 57 312 heads and intake the G heads were 57-59 The 57 intake are pricey for the money I would go blue thunder or Mummert But on EBay I see after market bird distributors in the $250 range. For less money and power Use a adapter on your manifold for a late style carb and the after market Distributor.
  6. The issue is his mechanical factory tach. I will agree that using the OEM all-vacuum distributor with the teapot is less than optimal, but finding a 'correct' tach-drive distributor with both mechanical and vacuum advance may prove to be all-but-impossible.
    I wonder if he could use one of those electronic-to-mechanical speedo drives to operate the tach. Knowing how many cable turns equals what RPM on the tach would be needed, but those all feature pretty wide calibration ranges and some research in what kind of signal it would accept may allow that to do the job.
    Or have the OEM tach converted to electronic, I'm sure someone could do that. Sunpro and some others make small-face electronic units, I'd think would be doable. These aren't all lo-buck solutions, but sometime you have to bite the bullet...
  7. 03GMCSonoma
    03GMCSonoma
    Have you thought about getting a cam from the '57 supercharged 312? I thik it holds the valves open longer to get more air/fuel into the combustion chamber. Just a thought.
  8. miker98038
    miker98038
    That’s why I asked for a picture. There’s some after market distributors with the tach drive, centrifugal advance, but no vacuum advance. With the curve set properly they work fine, just give up the part throttle advance that helps with gas mileage. There’s also a couple aftermarket’s with centrifugal and vacuum but no tach drive. Ted Eaton’s reviewed those.
    If it’s a stock 56 loadomatic with the can removed, it’s effectively a locked in distributor, and those don’t work on a street y block.
  9. 55blacktie
    55blacktie
    CRT has an electronic distributor with both mechanical and electronic tach-drive specifically for Y-block Tbirds. It has both centrifugal and adjustable vacuum advance. Price is about $250/w free shipping. It is made in China. However, a member of y-blocksforever.com sent one to Ted Eaton (eatonbalancing.com) for testing. Ted posted positive results on y-blocksforever.com.
    The 57 "G" heads are just as expensive (if not more) than the 57 intake. Heads made through April, 57 have been known to crack. Beginning in May, 57, the G heads were "posted," which reduced cracking. The recommended milling of non-posted heads is .025. Ted had a customer's posted G heads that had been milled .080.
    The 57 cam and G heads were used for the C (292), D, and E-code Thunderbirds. The G heads have nominal 69cc combustion chambers. F-code engines, being supercharged, had heads with 82cc combustion chambers. 113 heads were later replacements for G heads; they have the same size valves (1.92/1.52) but 72cc combustion chambers, as found on 55-56 heads and heads made 58-up. 471 heads are later truck heads/w same combustion chambers and valve sizes as F-code heads. All Y-block heads made beginning in May, 57 are posted.
    57 "square" exhaust manifolds are bigger than those used in 55-56. The 57 Tbird exhaust manifolds are being reproduced and are available from Tbird suppliers. Expect to pay about $600/w shipping.
    If you want to keep the Holley 4000 "Teapot" carburetor, which has a cfm rating of 390, there is a do-it-yourself modification that will render it compatible with 57+ distributors. You can find the article on eatonbalancing.com.
    Although there are adapters available that will allow you to put a 57+ carburetor on a 55-56 intake manifold, it will not flow as well as a 57/Mummert/Blue Thunder manifold. Also, hood clearance could be a problem, particularly if you also have the pcv-draft-tube carburetor-conversion spacer. You will have to use the stock air cleaner or an aftermarket air cleaner/w drop base, or your hood won't close.
    Send a pm to me, if you want more info. I have a 55 Tbird, and I've been down this road.
  10. jimmy six
    jimmy six
    You live in Escondido Ca. the home of John Mummert and his Y- Block business. Call him on the phone or drive over to his business and speak directly to him about what you are wanting to do. He has helped many Ford owners.
  11. pprather
    pprather
  12. fijidad
    fijidad
    I also remembered I bought this carb several years back, and I have the adapter to the original 4bbl manifold, so this may be part of the solution too. I will have to dig out the distributor and check it out...to see what variety I've got.
    Thanks for the other inputs.
  13. birdman1
    birdman1
    Can you put the internal parts from a 312 dist in the 55
  14. jimmy six
    jimmy six
    Not that I have heard or read. Any 57 up to 64 y-block distributor will work. Ford or Mercury.
  15. miker98038
    miker98038
    The upper body is different between the loadomatic and the 57 up centrifugal. But there’s an outfit called FBO in Cottage Grove OR who’s doing custom work and may be able to do that. But it’s custom machine and welding, so it won’t be cheap. They just finished a custom unit for a 368 Lincoln with 4 Webers on another board. Took a couple go arounds but they got it right.
    Okie Pete likes this.
  16. 55blacktie
    55blacktie
    Pretty extreme, considering there are other options.
  17. miker98038
    miker98038
    Yes. That CRT unit was a real game changer. Somehow I missed it had the tach drive.
