Technical 318 Intake Gasket help
Discussion in 'The Hokey Ass Message Board' started by Sharpone, Jan 13, 2025.
  1. Sharpone
    Sharpone
    IMG_2899.jpeg IMG_2900.jpeg IMG_2901.jpeg I ordered intake gaskets for a Mopar 318, I received steel gaskets. I’ve never used steel intake gaskets. I have an aftermarket aluminum intake.
    My questions are:
    -Are the steel gaskets OK for use with aluminum intake manifolds? Or are they for cast iron only?
    -The installation tips sheet says to use a thin coat of sealer on the underside of the intake ports, should I use some on the coolant ports also?
    -Should I purchase a fiber type gasket instead? Elderbrock, Cometic, etc?
    Any insight or experience is appreciated!
    Thanks
    Dan
    Truckdoctor Andy and Budget36 like this.
  2. 57 Fargo
    57 Fargo
    I use them on everything including aluminum intakes. I follow the directions and have never had a problem.
  3. Budget36
    Budget36
    Heck, I never knew steel shim intake gaskets were even made.
    Truckdoctor Andy and Sharpone like this.
  4. I’ve used them on an Oldsmobile, I would put a coat of Copper Spray gasket on them first.
    George, seb fontana, Jagmech and 2 others like this.
  5. SS327
    SS327
    Throw away the cork end seals and use Ultra black silicone bead in their place.
    Jagmech and Sharpone like this.
  6. garyf
    garyf
    318s always used steel. 360s used the paper. 3m yellow on the cork end rails on block side only,allow to dry completely so they wont push out.Bead rtv between cork and steel corners.
    jaracer and Sharpone like this.
  7. Sharpone
    Sharpone
    Thank you all.
    SS327 the only time I use only RTV is if I can’t get the seal to stay put.
    I thought about copper seal on both sides, but the do I still use the supplied RTV on the under of the ports?
    I’ve had good results with copper coat but never used it in conjunction with RTV
    Dan
  8. SS327
    SS327
    I used to coat lightly on both sides of the water ports with the ultra black. (Super thin)
    Ends use the ultra black silicone. Silver paint or copper coat around ports.
    Sharpone likes this.
  9. HSF
    HSF
    from Lodi CA
    Gasgacinch. Getting harder to find but it's out there.
  10. lemondana
    lemondana
    from Lincoln NE
    FelPro 1243 is the High Perf intake gasket set for the 273-318. It is the printoseal style, and I like to use these with an aluminum intake.
  11. Personally, I would not combine Copper Coat and RTV. RTV is fine for the end seals.
  12. Budget36
    Budget36
    I didn’t know 318’s used that type of gasket. I didn’t strip mine before taking it to the shop some 25/30 years ago, but a few weeks back pulled the intake and heads, just a “normal” felpro.
    Is there a reason 318’s used them?
  13. garyf
    garyf
    318 had smaller ports than 360-340,the reason for Chrysler smallblock gasket difference
    Budget36 and Sharpone like this.
  14. RodStRace
    RodStRace
    I know they were used and successfully. When I've replaced them, I've always moved to the fiber replacements. Just peace of mind, due to not squaring both surfaces and not wanting dissimilar metal contact, even though the bolts are also steel. The others have offered suggestions for ensuring a good seal. Your choice.
