318 Poly Speed Goodies?
Discussion in 'The Hokey Ass Message Board' started by 340HilbornDuster, Nov 13, 2012.
  1. hendo0601
    hendo0601
    from Tacoma, WA
  2. GregCon
    GregCon
    from Houston
    A stock 318 Poly will walk all over a stock LA 318. They're a great engine... a little heavy for their size and weight but still very nice running engines.
  3. EarlKann
    EarlKann
    The Weiands are a little cheaper than $1,000. Even the ones posted on ebay above in the $400-500 range seem a little high. I found one on my local CL for $120, sold it on ebay for $350 (plus $150 shipping to Aus). Paid $1200 for a complete P600 tripower with all newly rebuilt carbs, linkage and air cleaners.
  4. stillrunners
    stillrunners
    from dallas
    have driven most poly/LA's in my Mopars for years - currently have a 318/2 poly in the wagon and the old boat sure goes down the road pretty swift....
    my D300 truck gets around pretty good with a 318 and my oldest poly - a 277/2 (an in plant) in my Fury just won't give up....
  5. 340HilbornDuster
    340HilbornDuster
    I bored mine .090 over!!!! +
    (= 8 X 0.7854 X 4inch² X 4 = 402 ci.)
    4inch stroker kit from Campbell Industries:
    K1 Technologies 4340 forged crank - (4 Inch stroke)
    K1 Technologies 4340 Billet H beam rods with ARP2000 bolts
    Ross custom pistons, ring & wrist pins (8.0:1 compression)
    Clevite H series main bearings
    Clevite H series rod bearings
    Mains - ARP2000 bolts
    Cam & lifters from CamCraft
    .050 duration 232/232
    Lift 1.5 rocker .498/.498
    Lift 1.6 rockers .528/.528
    lobe separation 112
    Heads stock - Will probably get bigger valves, port job by Bobby's,
    1.6:1 blueprinted rocker arms
    6-71 Detroit Blower (reversed & set up for gas)
    Homemade Potvin style drive.
    Megasquirt EFI (i'll try to hide it real good)
    U-Fab-It "two runner" intake.
    Exhaust...U-Fab-it flange +...?
    Can't wait to fire it up!...still got lotsa stuff to do!
    T
  6. Dude, if you don't post pictures of that setup, I will swim over there and pound on you with a coconut! Awesome!
  7. 73RR
    73RR
    ...check out Chrysler Power magazine...
  8. 340HilbornDuster
    340HilbornDuster
    Anyone knows where I can get oversized SS valves, springs, caps & locks for the "318 "Poly?
    Mahalo
    Tommy
  9. 53 COE
    53 COE
    from PNW
    Sure is.... I just got in line for one........
    http://chryslerpower.com/webstore/Poly-SS-Manifold
    :cool:
  10. 73RR
    73RR
    53 COE, thanks for your support!
    Just so folks don't get confused by the photo, the new manifold will have a valley cover and t-stat housing as well as bosses for injection/NOX.
  11. Abomination
    Abomination
    It sure confused the hell out of me for a few minutes, until it hit me what was going on!
    ~Jason
  12. hotskins
    hotskins
    from Justin Tx.
    Go fast parts are out there, but we are sure proud of them. You can find good deals here and there. I have a bone stock 318 Poly with the 2 barrel and it hauls my Fury around just fine. I would like to get the 4 barrel intake for it, but until the prices go down, I will keep the stock intake on it. I have an adapter to put a 4 barrel on it, but it ran like ****.
  13. 35 Dodge Hot Rod
    35 Dodge Hot Rod
    from Mecca
    Now would be the time for anyone left holding a Weiand 4 barrel to sell it for a ridiculous number, and then go buy the improved 4 barrel version.
  14. 73RR
    73RR
    One sold on ebay about 2 weeks ago for $1025...:eek:
  15. EarlKann
    EarlKann
  16. 53 COE
    53 COE
    from PNW
    The time is now to get on the boat - All aboard!
  17. 35 Dodge Hot Rod
    35 Dodge Hot Rod
    from Mecca
    Well, to be fair the $1025 manifold was allegedly brand new without the box. It looked like it. But for christsakes that's still way out there in my book. I got a deal, but about 5 years ago I bought a Weiand dual quad manifold locally for $200 and chopped it up into a blower manifold.
    http://www.ebay.com/itm/Rare-Weiand...3TWIhdkifJ25fU7GbsF5g%3D&orig_cvip=true&rt=nc
    A nice tripower setup sold for $1500 a bit ago, but then again I believe that number is more realistic considering it had carbs and was essentially ready to run.
    http://www.ebay.com/itm/TRIPOWER-FO...3TWIhdkifJ25fU7GbsF5g%3D&orig_cvip=true&rt=nc
  18. EarlKann
    EarlKann
    That one I thought was fair. I bought the exact same setup from the exact same seller about 2 years ago for $1250
    Have not run it yet though.
  19. Speed Gems
    Speed Gems
  20. eppster
    eppster
    I've had five of them over the years. They had great driveability with good performance and excellent gas mileage. All were automatics with a 3:23 rear gear. The last one, a 65 Dodge Coronet 500 convt. , I tore apart and added a reground cam, four barrel, electronic ingnition and milled heads and I think it provided the same performance as say a 300 HP chevy small block. It really needed headers to attain more performance.
  21. 53 COE
    53 COE
    from PNW
  22. EarlKann
    EarlKann
  23. hotskins
    hotskins
    from Justin Tx.
  24. 66coronet500
    66coronet500
    I am working with a race engine builder on a 394 stroker poly. We spent some serious time (and money) porting the head till we felt we came up with good flow #'s without getting too aggressive. Then the ports were digitized and programed into the CNC machine and heads ported from that program. With the CNC porting all ports come out the same. We needed to sleeve the pushrods which came out very nice. We hit 1 water jacket but it was a intake port so it was patched up. We ran 3 different head flows. 11/32 and 5/16 valves on the hand ports then digitized these ports.CNC then done for these final #'s, 5/16 with some additional valve work. Here are the flow #'s all 28" with 1.94"' intake and 1.625 exhaust.[​IMG]
    11/32 int/exh
    .10 75/63
    .20 158/105
    .30 218/130
    .40 241/171
    .50 250/192
    .55 256/198
    .60 260/201
    .65 264/205
    5/16 int/exh
    .10 79/67
    .20 162/109
    .30 222/134
    .40 245/175
    .50 254/196
    .55 260/202
    .60 264/205
    .65 268/209
    5/16 with valve work int/exh
    .10 72/67
    .20 141/104
    .30 211/133
    .40 248/175
    .50 263/198
    .60 266/211
    .70 271/217
    Over the next month we will start to work up pricing and package for those interested. Feel free to ask any questions.
    Scott
  25. Dan Timberlake
    Dan Timberlake
    The Weiand 7503 went for over $700 bucks.
    http://www.ebay.com/itm/318-Poly-We...fJ1oj1ErBztLjpJ2VOwWc%3D&orig_cvip=true&rt=nc
    It looks like maybe it is a dual plane manifold, but each "plane" is one bank of cylinders. Like a cross ram with very short runners.
    I'll have to look thru my old Almquist catalog to see if that was a popular style, since I did not notice it before.
    The fellow that sold it is on the yahoo barracuda group.
    He paid what he thought was a lot for it several years ago, and when it brought over 700 bucks recently he said "Wow, I didn't see that coming."
    Can't believe the cylinder-to-cylinder distribution is very good.
  26. cagedruss
    cagedruss
    I know there is a little to much Aluminum on this engine for this Forum but this is a Customer's engine. I fabbed up the valve covers to clear the custom rocker shaft/rockers and modified pedestals. It is a stroked/bored poly and has very high numbers. It was a long time in the making and the engine is looking for a new shell to go in to.
  27. murfman
    murfman
  28. 66coronet500
    66coronet500
    Here is the pricing for the CNC ported poly heads. Also some pics of the crossover fill.​
    617-926-0608​
    gregg@hekimianracing.com​
    Using Clients Poly Heads​
    Price $2,800.00​
    CNC Stage 1 for one pair Bare​
    Hard exhaust seats​
    Performance Valve job​
    Machine, Install new 5/16" Bronze guides​
    Hone Valve Guides to spec's​
    Flat Mill Heads up to .010"​
    Open / Cut Spring Pockets​
    Open Pushrods holes and install bronze sleeves​
    Crossovers filled with 2000 dg F material​
    Pressure checked heads after work is done​
    Any unforseen issues are at an extra charge.​
    Flow Numbers 28" OF WATER​
    .100" .200" .300" .400" .500" .550" .600" .650"​
    Intake 1.94" ​
    79 162 222 245 254 260 264 268
    Exhaust 1.625" ​
    67 109 134 175 196 202 205 209
    Customers heads that have not been crack tested are subject to a release of all demands signed do***ent before any work can be done.​
    These heads with proper ***embly & a good intake manifold flow with a calculated componet configuration can produce over 500 HP
  29. Dan Timberlake
    Dan Timberlake
  30. fstfish66
    fstfish66
    from eastern pa
    as stated above, the poly yahoo group and chrysler power are currently building a affordable 4 bbl intake for the 318 poly,,,
