Hot Rods 32 2 dr sedan help needed
Discussion in 'The Hokey Ass Message Board' started by perrytudor32, Dec 20, 2017.
  1. perrytudor32
    perrytudor32
    from uk
    hi all,can anyone post up a pic of the brackets that hold the rear seat in place on the rear uprights.thanks in advance and merry xmas from over the pond.phil.
  2. stillrunners
    stillrunners
    from dallas
    bump up for the late crowd....
  3. car doctor
    car doctor
    I will get you a picture of mine tomorrow afternoon.
  4. Just Gary
    Just Gary
  5. perrytudor32
    perrytudor32
    from uk
  6. Hot Rod Dan
    Hot Rod Dan
    from Texas
    Hey Phil, Here's a pic of the inside of mine without the rear seat .
    The cutouts in the rear window panel marked "A" shows where the rear seat upper "hooks" fit over the horizontal body bracing to hold the upper seat springs in place. Down on the vertical bracing marked "B" is where the upper seat spring bolts to the body.
  7. Hot Rod Dan
    Hot Rod Dan
    from Texas
    And here are the pics of the brackets.
    Hope this helps, Merry Christmas. Dan
    mgtstumpy likes this.
  8. car doctor
    car doctor
    Mine has the same set-up.
  9. hotrodA
    hotrodA
    Thanks, also. Perfect timing, I Just started on my rear seat install.
  10. perrytudor32
    perrytudor32
    from uk
    thanks so much for that dan.that wasn't what I expected to see at all.i don't think those brkts are on my seat.i may have to get back to you for some measurements of the brkts if there not there.have a great xmas.phil.
  11. Hot Rod Dan
    Hot Rod Dan
    from Texas
    Both of you are welcome. Let me know if you need measurements (in inches of co**** :)).
    harpo1313 likes this.
  12. perrytudor32
    perrytudor32
    from uk
    inches is fine with me.will try and get down the garage next week to check.ta phil.
  13. hotrodA
    hotrodA
    Hey Dan.... Do the upper seat hooks actually hook over the tack strip/brace? Mine are too high by an inch, with the bottom holes lined up, and the cushion frame won't go to the rear far enough, hitting the curve of the tackstrip/brace.
    These two small brackets are bolted to the tack strip, outboard of the vertical braces, and look like they might have held a wood strip (with the two factory holes) that the upper hooks would go over. Any suggestions? This seat is a real PITA! Thanks! Bill
  14. Hot Rod Dan
    Hot Rod Dan
    from Texas
    Hey Bill,
    I didn't have any brackets like yours on my car. The seat brackets just hook over the horizontal body bracing/trim strip. Below are a couple pics of our car.
    Below is a pic of someone else's stock tudor. You can tell how high the rear seat upper spring sits relative to the rear window in this shot.
    Hope this helps.
    Dan
  15. hotrodA
    hotrodA
    Thanks Dan! Mine looks just like yours.
    It has to be an issue with the seat back frame.
    Adapt and overcome! After all, it's an old hot rod, not a stocker.
  16. 325w
    325w
    IMG_2098.JPG IMG_2097.JPG Here's some brackets on the fordoor rear seat upper wooden frame
  17. hotrodA
    hotrodA
    26907125_1779511178786504_1415379628914686470_n.jpg SOLVED MY PROBLEM! It's a tack strip alright, but it goes ABOVE the rear window, That explains the three reliefs cut in the upper wood frame. In case somebody else runs into this.
