Hot Rods 32 3-Window door glass regulator location.
Discussion in 'The Hokey Ass Message Board' started by Kenai, Aug 4, 2024.
  1. Kenai
    Kenai
    I am putting manual windows in a '32 3-window. Fibergl*** body, 1-1/2" chop, with no indication of where the 7 holes for the regulator and crank should be. I have access holes, but otherwise a smooth surface. I have looked at every '32 I know of within 100 miles and they have all gone to electric windows and when you pull a screwdriver out of your pocket at a car show, folks get nervous. Would anyone have the measurements from a couple places on the door for locating this? I would really appreciate it.
  2. pprather
    pprather
  3. Kenai
    Kenai
    Phil: Thanks. Pictures are great. Looks like the unit is parallel to window edge, which makes sense. A couple of measurements would lock it down.
    pprather likes this.
  4. pprather
    pprather
    Welcome to the HAMB from Illinois.
  5. deathrowdave
    deathrowdave
    from NKy
    Should be able to scale from window opening in the photo to measure for the regulator , maybe
  6. Andy
    Andy
    I could measure up from the bottom and from the back to the crank center.
  7. Kenai
    Kenai
    Andy, I would be most grateful. I could try to scale off the photo as Dave suggested, but a couple of numbers I am sure would get me closer to correct.
    Mike
  8. Kenai
    Kenai
    Phil: Thanks for the welcome. I have pilfered answers to questions from the HAMB for years. Figured I should finally join in.
  9. Andy
    Andy
    I will get them tomorrow.
  10. Andy
    Andy
    I actually followed up!
    From the back of the door forward To the handle centerline--- 27"
    From the bottom of the door up to the handle centerline----20"
    These are not rounded off. These are what I measured.
    Hope it works for you!
  11. Kenai
    Kenai
    Andy, Thanks a bunch. Just what I needed.
    Mike
