Technical 32, 33, 34 firewalls into a model a?
Discussion in 'The Hokey Ass Message Board' started by oliver westlund, May 13, 2024.
  1. oliver westlund
    oliver westlund
    Okay, I am searching for some opinions that a handful of searches havn't turned up. I have a 30 roadster. It currently has a stock firewall. The car is going on 32 rails. Flathead v8 powered so engine space isn't an issue. I don't want a stock firewall. Initially I set out for a 32 firewall. Pros- its cool, bolt in instead of weld in...maybe I could chrome it? As I was reading about the subject, I learned that a 33/34 pickup has more leg room than a 32 due to the firewall. So I started considering those. Now I am picking up a great deal on a 33/34 firewall. I dont have to use it but I had to grab it. I also have a butchered piece of a 32 cowl. The 32 cowl has no firewall or w/s posts but it has the rest. I have some options from here as I see it. I could weld the 33/34 firewall into the model a and gain some leg room and a cooler look and call it a day. Or I could try to convert the 33/34 firewall to set a touch deeper into the cowl and be bolt in? Could still chrome it if I did that... I could sell the 33/34 firewall and continue to hunt for a 32. Dont know if the 32 pickup cowl bits would be handy for any scenario but I have it... was only 60 bucks so I figured why not. Any thoughts or insights are much appreciated!
    scotts52 likes this.
  2. The37Kid
    The37Kid
    The roadster door alignment & fit depend a lot on the firm fit of the firewall/cowl structure, you'll have a lot of work equaling that. I'll follow along, post lots of photos. Bob
    chevyfordman and oliver westlund like this.
  3. junkman8888
    junkman8888
    From what I've seen the '32 firewall is taller and wider than the firewall on a '30-31, still, with a little slicing and dicing you can make it work.
    oliver westlund likes this.
  4. oliver westlund
    oliver westlund
    Iron trap garage has a video or 2 showing one way to do it. Its not too crazy of a task and has been done by several folks on here. Never seen a 33/34 pickup firewall though
  5. oliver westlund
    oliver westlund
    I will, I have a build thread on the car. I havn't really gotten too deep into it yet but once I finish the car currently in my stable it will start flying along with plenty of pics!
  6. Tim
    Tim
    from KCMO
    I’ve seen quite a few 32 firewalls put into model A’s. I don’t know if I’ve ever knowingly seen a 33/4 though
  7. Taboo56Chevy
    Taboo56Chevy
    Not a bad idea to make a pickup firewall fit a model A. Depending on the engine you are gonna run will kind of determine if its worth it over a 32 firewall. Alot of 33/34 pickups have the firewalls cut out mainly to give more room for OHV V8's. If you have to set the 33/34 firewall back anymore than 3/4"-1" then you lose all the gains of the of the pushed out toe area.
  8. DDDenny
    Deuce firewalls are gold nowadays, hope you saved your pennies!
  9. The37Kid
    The37Kid
    A bit wider, so buying a cutup one should be cheaper than cutting up one that could still fit a '32.
  10. oliver westlund
    oliver westlund
    Thats good to know! Its getting a 59ab so space should be plentiful!
  11. oliver westlund
    oliver westlund
    Yeah like 900 bucks! Then if I chrome it Ill have about 3-4k into my firewall haha
  12. DDDenny
    Cool, that would make a nice mirror, then you could set the timing AND shave.:p
  13. alchemy
    alchemy
    A 33-34 pickup firewall looks like an A firewall if you squint. Why go through the work for no benefit?
  14. k32t
    k32t
    from Hog town
    bump out the A firewall use a piece of plywood and attach a polished piece of stainless!
    Speccie and oliver westlund like this.
  15. el Scotto
    el Scotto
    from Tracy, CA
    I've seen the '32 firewall in a few model A's before but if it were me I'd probably go the Milner Coupe or Baskerville roadster route with the firewall.
    Something flat and polished. Aluminum or Stainless. Maybe even engine turned.
    If you wanted to you could even use '32 feet as a mounting basis and build off of that.
    Just my $2 (adjusted for inflation :D)
  16. Bandit Billy
    Bandit Billy
    Most I've seen are white.
  17. oliver westlund
    oliver westlund
    Added leg room?
  18. oliver westlund
    oliver westlund
    This is the firewall I made a deal on.
    To my eye it has a much different look than a stock model a. Screenshot_20240514_222300.jpg
    I am still strongly considering trying to figure out how to make it a bolt in firewall as well. Not sold on any particular route yet though. I know I do not want a stock model a firewall
    Tim likes this.
  19. alchemy
    alchemy
    So the ribs go in different directions? The depth of the firewall is pretty close to the A, so I don’t think you are gaining any foot room if that’s what you’re after.
    You do you, man.
  20. continentaljohn
    continentaljohn
    So a deuce firewall is pretty much the same dimensions as the 1933 1934 ford truck firewall . The difference is one sticks out 33-34 and one goes in towards the interior 32. The height is the same the width is the same even the holes line up.
    The 1932 truck will except the 1933-34 firewall as the 32 firewall will fit the 33-34 cabs as the cowls are the same. Even the rare roadster pickup fits all the years.
    Now fitting them in a model a 30-31 the bottom of the model a cowl will have to be spread out an inch or so. Now if you just use a 32 firewall with out the feet you don’t have to spread it out much at all as the width is on bottom.. image.jpg IMG_7096.jpeg IMG_7099.jpeg IMG_7098.jpeg IMG_7097.jpeg IMG_7100.jpeg IMG_7101.jpeg IMG_7102.jpeg image.jpg IMG_7096.jpeg IMG_7099.jpeg IMG_7098.jpeg IMG_7097.jpeg IMG_7100.jpeg IMG_7101.jpeg IMG_7102.jpeg
  21. The37Kid
    The37Kid
    John, Thanks for the photos!
  22. oliver westlund
    oliver westlund
    Fantastic! Thanks John!! I'm guessing mounting on the frame is similar? I have a 32 frame
  23. oliver westlund
    oliver westlund
    Johns pics and info have me leaning toward fitting the 33/34 pickup firewall and converting it to be bolt in...could still chrome it that way. 32 firewalls are just so hard to come across and carry such a high price tag
    chevyfordman likes this.
  24. continentaljohn
    continentaljohn
    @oliver westlund yes mounting it on a deuce frame is perfect and just have to spread out the model a roadster cowl a bit. The 32/firewall height is 28.5 inches or so less then .500 differences with the 30-31 roadster cowl so very minimal. The width as you see in the picture the deuce firewall is wider on a 32 at the beginning of the feet top and tapers at the very bottom . A few pictures of 30 31 cowl and firewall. It’s been a while since I did one but remember it wasn’t too bad. IMG_7113.jpeg IMG_7114.jpeg IMG_7115.jpeg IMG_7116.jpeg IMG_7117.jpeg
  25. continentaljohn
    continentaljohn
    Lots of deuce firewalls about just talk to a hoarder :D. If your heart is to chrome one I would be looking into the united pacific one. They are close and lines aren’t sharp like a real one but most 32 firewalls have extra holes ,cuttings, pitting and rust issues. You can find ones that need love or feet for 400 bucks or so. Just a thought
  26. mgtstumpy
    mgtstumpy
    Model A firewall (Body) modified to fit an OEM 32 frame by HAMBer (Flop)
  27. oliver westlund
    oliver westlund
    Thanks john, a lot of help!
  28. oliver westlund
    oliver westlund
    Smart idea!
  29. oliver westlund
    oliver westlund
    Ended up deciding it has to be a 32...so I am on the hunt for one again!
  30. twenty8
    twenty8
