'32-'34 Ford oval track tips- Honest
Discussion in 'The Hokey Ass Message Board' started by sidevalve8ba, May 29, 2013.
  1. sidevalve8ba
    sidevalve8ba
    According to the 1961 Honest Charley catalog these are the hot set up for suspension for your '32-'34 for for the dirt track. There is even information about setting up you banjo rear to stay cool. Enjoy :D
  2. sidevalve8ba
    sidevalve8ba
    Check out some of the prices of the parts.
  3. el Scotto
    el Scotto
    from Tracy, CA
    That is pretty cool!
  4. print is too small for me to read.....what is the reason they recommending bending the right side of the front beam axle back 3/4" ?
  5. sidevalve8ba
    sidevalve8ba
    Quoting the item it says,"Now the finishing touch - FRONT AXLE TO BE BENT (cold) 3/4" BACK (not forward) just from the Perch out to the spindle. Use stock '39 Ford Truck 16" (front) wheel on LEFT - USE 15" OFFSET ON RIGHT 16x600 ON LEFT 15X700 ON RIGHT. USE STOCK CAMBER ON LEFT AND 1 1/2 degrees NEGATIVE CAMBER ON RIGHT. 1/8' TO 1/4" toe in."
