does anybody out there have the dimensions for the stake pockets. these _l L I have to grab a full sheet of metal for the shop so I thought I'd go ahead and have them break the general chanel shape for me for that project since they're brake is way better than mine.
I wonder if Mack Products ((660) 263-7444, wwwmackhils.com) sells anything you could use? They are the supplier that specializes in truck beds. Charlie Stephens
Before making your own I'd check around the people that sell complete PU boxes. A friend of mine bought just individual components for his '34 box when he built the truck a couple of years ago. Frank
I had more time than money at the time we made the bed so we fabricated the pockets,,I'm sure they are not to specs. HRP Front... Rear...
Mac's has them. Relatively cheap, unless you want to fab them yourself: http://macsautoparts.com/cart.asp
Probably a good idea if you actually want to use stakes. I chose not to make provisions for them. HRP
And they have all the proper beads too, if that's a consideration. I used them on my bed to match the original look. They fit perfectly out of the box. I figured I'd make nothing but s**** by trying to fab my own.
I could buy them, but that's $40 a piece versus a little time and no guarantee they'll fit the bed sides the PO had made for the new bed. my cheap gene kicking in here since I have to buy a full sheet to get the size I need. stakes aren't functional HRP how wide and deep are yours? flange/lip 3/8 or 1/2?
Mack Products makes them and have them listed on their website for $34 ea front or rear. They are very nice quality. Posted using the Full Custom H.A.M.B. App!
I have side profile templates I made from a friends originals. I was too cheap to spend $37 a piece so I made mine out of some 18 gauge. I bent them up, traced the side profile,cut the excess out,and welded them up. I can get you some measurements tomm. I believe they are aprox. 19" top to bottom and I put a 1/2 lip on each side Posted using the Full Custom H.A.M.B. App!
^^^^^ saw yours in the build thread. just need some dims. curious to see how close yours are to what HRP did with his.
Mine measure The pockets measure 2" x 2 1/4" x 2" (1/2") flange on both sides. The length is 21" and the taper starts at 12 1/2" Hope that would help. HRP
