32-34 Ford truck (2 questions)
Discussion in 'The Hokey Ass Message Board' started by HOTRODPRIMER, Sep 16, 2003.
  1. HOTRODPRIMER
    HOTRODPRIMER
    Is a 32 ford truck grill shell the same size and shape of a 33-34 shell?
    If it is will it fit on a 34 truck with the original 34 hood
    without any modifications?,,,HRP
  2. dondanno
    dondanno
    33 34 truck grilles lean back the 32 is more vertical. Hope this helps...Danny
  3. fab32
    fab32
    Not only does the '33/'34 grill lay back but it is wider front to back. The grille bar section is stamped into the shell like the '32 truck which does not have a removable grille bar section.
    Frank
  4. hatch
    hatch
    from house
    and fab32 should know...he has about a gozillion of em layin out on the pile [​IMG]
  5. TV
    TV
    If you have a 32 shell it will bolt right on, then get new hood tops from Rootlieb, and your all set.--TV
  6. zonkola
    zonkola
    from NorCal
    The hoods are shaped differently, too. Check these out from Rootlieb's website.
    1932
  7. tommy
    tommy
    All 3 years of commercial grills are different from the same year p***. grills. All 3 years are different from each other. The 33-34 grills interchange but they are different around the filler neck. I've never tried but I'd be surprised if a 32 could be used on a 33/34 radiator. P.S. The comm. and p***. radiators are the same for their respective years.
  8. HOTRODPRIMER
    HOTRODPRIMER
    Thanks guys,the shell i was eyeballin' won't work with what we have ,,,,so i got a line on a 33 shell!...HRP
    lothiandon1940 likes this.
