Technical 32-34 pickup
Discussion in 'Traditional Hot Rods' started by old chevy nut, Jun 3, 2017.
  1. old chevy nut
    old chevy nut
    from va
    has anyone ever mounted a 32-34 pickup cab on a 35-40 frame? could it be mated together to do a full fenderd pickup? just curious
  2. 325w
    325w
  3. Texas Webb
    Texas Webb
  4. 1936chevy
    1936chevy
    Chevy or Ford? Is is safe to ***ume chevy because of your username? :)
  5. HOTRODPRIMER
    HOTRODPRIMER
    The word "ABORTION" is the word that comes to mind,and no,it wouldn't be mated together to run fenders.
    HRP
    WiredSpider likes this.
  6. Petejoe
    Petejoe
    from Zoar, Ohio
    Seen a complete 34 ch***is just posted on the H.A.M.B. For sale.
    Do it right or throw your work and money at something you'd be embarr***ed to will to your kids.
    HOTRODPRIMER likes this.
  7. sloppy jalopies
    sloppy jalopies
    '35 to '40 Ford frames are much wider than a '32-'34 ... memory says almost 2" per side... dashes are about 4" wider... frame has a 2"plus rise from the cowl toward the front x member, may have to chop your grill and trim your hood sides ?
    where '32 fenders bolt to the frame top they are almost flat with a slight rise toward the front... '33-'34 fenders / frame have a 2" or so arch built into them...
    '35-'40 ch***is had the front axle moved back behind the x member which may change its arch...
    you could replace the front and rear crossmembers with model As and rework the x members and then slide the rails closer together so they match the firewall measurements of your cab...
    .......think petejoe has it right...
    a '32 wheelbase is 106", '33-'34 wheelbase is 112"... similar measurements from the cab forward so ... IMO. the '33-'34 box can be a little worktruck looking...
    decide now before you buy...
    ... good luck, have fun...
