Technical 32-34 roadster windshields?
Discussion in 'Traditional Hot Rods' started by dumprat, Oct 9, 2017.
  1. dumprat
    dumprat
    from b.c.
    How much difference in size is there between the 32 and 34 roadster windshield? Can't seem to find a 34 that has the adjustable feature. And there is an og 32 screen that keeps popping up locally.
  2. Pewsplace
    Pewsplace
    Completely different windshield posts. Deuces are two piece and model 40 are single piece. The 34 can be leaned back by cutting the post and re-welding.
    LOU WELLS and kidcampbell71 like this.
  3. xix32
    xix32
    A `34 roadster windshield frame sides are curved, a `32 is straight until the very bottom curved area
    LOU WELLS likes this.
  4. sloppy jalopies
    sloppy jalopies
    buddy goes to a boat supplier for the 2 posts... don't fold.
  5. dumprat
    dumprat
    from b.c.
    Ok those are both things I realize. Question is can I put a 32 windshield and stanchions on a 34?
  6. mitch 36
    mitch 36
    Every thing can be done, it will just require some indepth thinking and fabbing on your part. It would probably be easier to m***age the body to fit the 32 stanchions than to try to rework the stanchions themselves. Mitch.
  7. dumprat
    dumprat
    from b.c.
    That is kinda what I figured. I can't believe nobody had tried this. Not exactly rocket surgery
  8. I plan on a folding windshield on my '34 tub ( long term project.) I was going to modify my '34 posts like a '32.
  9. dumprat
    dumprat
    from b.c.
    I wonder if you could use 32 posts and modify the 34 frame to fit?
  10. Anything is possible I suppose? I've never had a '32 frame to compare with my '34?
    Somewhere I have some pics I've saved of a modified '34 post. Everything has been done before...
    dumprat likes this.
  11. dumprat
    dumprat
    from b.c.
    I don't have either at this point, but I know what I want it to look like.
  12. flynbrian48
    flynbrian48
    It'd almost be easier to start from scratch, as pointed out you can do anything if you're determined enough. There's enough difference that I can't see making a '34 frame fit '32 style posts, or vice-versa.
