Hot Rods 32 brake master cylinder
Discussion in 'The Hokey Ass Message Board' started by 1932tub, Feb 8, 2021.
  1. 1932tub
    1932tub
    In my 32 5 window I have a 72 ford master cylinder which has a 1" bore. While it stops fine I would
    like an easier brake pedal. Leverage is the max I can get so I am thinking about resleeving the cylinder to a smaller diameter to give a better pedal. I am unsure how small to go has any one done a similar excercise? Front brakes are 56 F100 rears are Ford 9". Thanks.
  2. Deuce Lover
    Deuce Lover
    Get the MC with the 7/8" bore and switch it out. Which side are the ports on your MC?
  3. V8 Bob
    V8 Bob
    Check that you don't run out of pedal travel before fully stroking the M/C with a smaller bore, and loosing the dual system safety advantage.
    HemiDeuce and dana barlow like this.
