Projects '32 brake pedal
Discussion in 'Traditional Hot Rods' started by terry k, Jun 30, 2019.
  1. terry k
    terry k
    from toledo oh
    I thought I saw that someone made a replacement brake pedal for the '32 Ford with a '39 trans. It had the lever moved to the bottom. Drake has one for the "36.
  2. clem
    clem
    I don’t understand your question, the brake pedal doesn’t have anything to do with the transmission does it ?
    ct1932ford likes this.
  3. IronFord
    IronFord
    from NoDak
  4. terry k
    terry k
    from toledo oh
    Sorry ,I meant with hydraulic brakes ('39 master cyl). It does have a '39 trans.
  5. alchemy
    alchemy
    Industrial Ch***is in Arizona used to. Not sure if they still do.
  6. m.ralph
    m.ralph
    Check Bob Drake Reproductions, he's in Oregon.
  7. I used the stock '32 pedal ***embly with a bracket I made to mount the '39 master cylinder behind the K member (see attached).
    Charlie Stephens
    kidcampbell71 likes this.
  8. terry k
    terry k
    from toledo oh
    Nice job !!
  9. Andy
    Andy
    I have not done it myself by I thing it would work. It used the stock mech. brake bellcrank and linkage but mounted a M/C on the p*** side of the trans where the parking brake was.
  10. Bruce Lancaster
    Bruce Lancaster
    Vern Tardel has a book on brake conversion for '32 in which he mentions a complete pedal he sells...but I don't think it exists on his parts site. I've seen other such mentions in his books. Maybe he is planning a line of parts?
    Anyhow, most common route was to cut off stock lever and weld it to bottom of pedal or use an equivalent fabricated piece down there.
    The Norwegians have posted a conversion here mounting MC in the triangular space in crossmember pointing forward with a Ford brake rocker moved over to transfer the stock pedal movement forward!
    Shop
    Ford Brakes - Hydraulic Brakes for Your Early Ford - Book #3
    $11.95
    Moriarity and kidcampbell71 like this.
  11. Bruce Lancaster
    Bruce Lancaster
    [​IMG]This is setup described by Klazurfer...there is more info on here somewhere
    Moriarity likes this.
  12. bct
    bct
    I converted a set of 37 pedals into a 32 pedal box for use on 39 trans.
  13. bct
    bct
  14. ct1932ford
    ct1932ford
    With stock cross member a simple bracket is needed. They are sold someplace. I will have to check. Coleman R&R 015.JPG
    My Coupe
    My Roadster. Sorry best photos I could find.
  15. seabeecmc
    seabeecmc
    Fogger and lodaddyo like this.
  16. lodaddyo
    lodaddyo
    yep, I would contact dennis. he has what you need
  17. clem
    clem
    This is how mine was done by previous owner, but with today’s laws, down here, it may need the welding to be crack tested or similar.
  18. my2nd40
    my2nd40
    from Tennessee
    I used Dennis Lacy's. No need to cut and weld anything with his parts.
  19. terry k
    terry k
    from toledo oh
    I had a Lacy and just sold it. How do you get ahold of Vern Tardel ? No phone number, tried using he message board on his web page, sent a text, but no answer.
  20. sloppy jalopies
    sloppy jalopies
    I let the stock pedal pull, not push...then I run about 46" of 3/8" steel rod turned down and threaded 5/16"-24 for about 1.5" on each end...mounts the master in the trunk... no carpet trap door to add fluid..
    then a belcrank, pull rod to the bottom where I drill [3] holes that give an option of changing the mechanical advantage... with the master cylinder at the upper end, now pusher end...
    by mounting the master cylinder above the wheel cylinders I did not use residual valves...
    only pic … the 5/16" pull rod is painted red... DSCN0616.JPG
  21. fuchster
    fuchster
    from San Diego
  22. fuchster
    fuchster
    from San Diego
    I got this from an old man who said he got it from a guy named Henry. That it came from his super rare stash of parts
    Airborne34 likes this.
