Technical 32 chassis front brake lines
Discussion in 'The Hokey Ass Message Board' started by ROBERT JAM, Sep 20, 2015.
  1. ROBERT JAM
    ROBERT JAM
    looking for pics or ideas on where to run the front brake lines to the rubber hoses on hyd brakes. I'm running into my drag link when placing them on the bottom of the ch***is. I tried through the frame mounts but couldn't find fitting for the an3 to old ford thread on the rubber hose. Any body put the line on the top of the frame? Help is appreciated
  2. Dennis D
    Dennis D
    Something like this? D
  3. ROBERT JAM
    ROBERT JAM
    Dennis can you fill me in on what you did
  4. Dennis D
    Dennis D
    Cut the AN fitting off and drilled and tapped the hole for 1/8 NPT and installed the inverted flare fitting that worked with the rubber hose I am using. D
    texkbc likes this.
  5. ROBERT JAM
    ROBERT JAM
    Dennis thanks for the info
  6. Dennis D
    Dennis D
    Welcome, D
  7. Ol Deuce
    Ol Deuce
    from Mt. U.S.A.
    Bob ...did you get those ends cut off yet???
