Projects 32 chassis hits the ground for the first time
Discussion in 'The Hokey Ass Message Board' started by big duece, Nov 25, 2010.
  1. 383deuce
    383deuce
    Greg,
    The new floor looks outstanding.....The whole project is looking great. Bob would be proud of you with what all you have done and the quality of workmanship.
    Dennis
  2. raven
    raven
    Well, now get that thing on the road!
    r
  3. dad-bud
    dad-bud
    Great looking build - looking forward to updates as progress happens.
    Thanks for sharing.
  4. Old Tin and New Tin
    Old Tin and New Tin
    Keep plugging away. You are doing it right.
  5. Pewsplace
    Pewsplace
    Very nice! Don't give up on the dream. You have some talent for this hobby.
  6. 2deuces64
    2deuces64
    Look'n good Greg! Looks like you've got all the big pieces. Have fun!
  7. big duece
    big duece
    from kansas
    Made some more progress today. I couldn't wait to see if my wheelbase was going to line up with the wheel wells, couldn't be happier. Kinda like framing a house, seems like a lot gets done and then it comes to a crawl. There is a few items, like the cowl has been spread apart at one time when it was channeled. The rear subrail extensions are just dry fit, and need to be properly fit. Overall I am very happy with the stance, and was hoping the car didn't set too level. I wanted a bit of nose down rake. I have a standard eye rear spring if I want to switch out the reverse eye to raise the rear a bit.
  8. big duece
    big duece
    from kansas
    Thanks Dennis. That means alot to me. If I could change anything on this build, it would be to working next to dad. He is responsible for talent and p***ion for 32's that I have today. I am building the car he always wanted , but could never afford as a kid.
  9. groundpounder
    groundpounder
    Theres just something about a '32 going together......it's a work of art!...Awesome ride and pics!
  10. Roadsir
    Roadsir
    That is a nice simple build, Looks great
    Eric
  11. alfin32
    alfin32
    from Essex, Ma.
  12. The37Kid
    The37Kid
    That looks great, nice to see you have a lot of proper tools for the job. Wheel well fit looks great, I was told using a pair of rear fenders will get things factory perfect. Fenders and cowl are the only points that will get a channeled body back to factory location. Bob
  13. big duece
    big duece
    from kansas
    I dont have any rear fenders to use as a gauge, so it will be lots of measuring and what looks good. Once I get the doors hung, I plan to them as a gauge for adjusting. Not sure how to pinch the A pillar post back. It appears they were spread apart when it was channeled, must have been channeled over a wider frame other than a 32.
  14. T&A Flathead
    T&A Flathead
    Looks good. I've been just where you are at, except your body looks really nice. Good job.
  15. greaser
    greaser
    Nice project! Looks like you got it under control.
    Just to start a discussion of ideas for re-shaping the A pillars:
    A rigid pattern made from another 32 would be very useful....(full height of A-pillar from top to bottom). Perhaps you could use heat and some pipe clamps to gradually squeeze the A pillars back into contour.
    This approach may be crude, but without all the neat tools, I usually try to simplify things.
    Maybe others more experienced will suggest better methods.
  16. big duece
    big duece
    from kansas
    The drivers door pillar seems to fall right where it needs to be, I hung the drivers door and I fits very well on the 1st attempt. The p*** pillar is the one that is kicked out at the bottom. I need to do some more measuring from key points to see where to manipulate the pillar. Its obvious its between the dash support and the bottom of the pillar. I like the idea of a template, now to find a stock 5w that is local to make a pattern or take measurements.
  17. 383deuce
    383deuce
    Greg,
    This is looking better everytime I check in on you. Ya should be able to go over and check the measurements out on Tink's 5 window if you can get him to unload all the parts inside it. Might be a good reason to get him fired up to finish it.
    I like the tire fitment on the back of yours.
    Keep hammering away....
  18. sodbuster
    sodbuster
    from Kansas
    Nice! Not sure how I missed this post.
    Chris Nelson
    Kansas
  19. big duece
    big duece
    from kansas
    Really have a blast working on this 5w, the doors are fitting pretty well. I have the floor fastened down and fitting the A and B pillar brackets. Dry fitting as much as I can before any welding. Also scored a NICE pair of Indy roadster Halibrand mags from Hamber "frames", thanks again Dennis. Rear tires may be firestone Indy, or 8.90x16 dirt track.
  20. HOTRODPRIMER
    HOTRODPRIMER
    Everything looks like it's fitting good,I like the wheels. HRP
  21. 383deuce
    383deuce
    Ya just had to dangle those kick *** new wheels in front of us....I really like them. way to go guy.
  22. HotRodHighley
    HotRodHighley
    from cincy, oh
    Looking good. The stance look killer. Keep up the great work!
  23. ct1932ford
    ct1932ford
    Nice Work! Looks Great.
  24. Stevie Nash
    Stevie Nash
    Buying and building the frame before the body. Interesting... Now you've got me thinking. :cool:
  25. Pewsplace
    Pewsplace
    Looking good! Did the 700R4 fit the CE X member without cutting? I am doing the same thing and George at CE told me a 700R4 would not fit. Yours looks like it fit perfect.
    Lynn
  26. woodbutcher
    woodbutcher
    :D Looking good.
    Good luck.Have fun.Be safe.
    Leo
  27. big duece
    big duece
    from kansas
    Yes, I did modify the ch***is engineering X member. But just a small amount on the p*** side. The other pics show the new United pacific pillar parts.
  28. paleot
    paleot
    from louisiana
    WoW That will Be a Great ROD!!!!!!!!!!!!!!!!!!!
  29. Pewsplace
    Pewsplace
    Thanks, that is nothing and similar to the notching on a 34 and 40. Looks good.
