32 Chassis: Rolling Bones, Ionia, and Patina Steve
Discussion in 'The Hokey Ass Message Board' started by patina steve, Dec 14, 2009.
  1. patina steve
    patina steve
    So I took the roadster out to the 75th Deuce reunion. I meet Ken and Keith from the rolling Bones, also Matt and Dennis from Ionia Hot Rods..……….Look what happened ………. Well Bob a friend of mine wanted to build a hot rod chassis so this is the results a lot of influence from the Bones Boys and Iona Boys with a little of my own …….
    TA22 and spiffy1937 like this.
  2. Uptown83
    Uptown83
    looks awesome
  3. hotrodladycrusr
    hotrodladycrusr
    Denny and Matt Lesky owners of the Ionia Hot Rod Shop are the salt of the earth. You'd have a hard time finding nicer folks.
    Your chassis looks great. Congrats!
  4. CheaterCarl
    CheaterCarl
    those dudes build some of the coolest looking chassis!
    much respect!
    Cheatercarl
  5. trestles126
    trestles126
  6. Mr48chev
    That looks great. Almost too nice to cover up with a body.
    <input id="gwProxy" type="hidden"><!--Session data--><input onclick="jsCall();" id="jsProxy" type="hidden">
  7. JeffreyJames
    JeffreyJames
    from SUGAR CITY
    Ha! That's pretty much what my Ionia Chassis is going to look like. Great looking work!
  8. McFly
    McFly
    Is that 5w getting plopped onto that bitchin' chassis? Looks like a super clean body.
  9. thunderbirdesq
    thunderbirdesq
  10. greazhonkey
    greazhonkey
    Nice looking chassis, good job.
  11. Nice! any pics of the inside frame area of the front shocks?
    BTW....the guys from the "Rolling Bones" are also pretty salty earthy guys...stopped in there a few weeks ago,,,,,Nice stuff!
  12. solid
    solid
    yep...
  13. VAPHEAD
    VAPHEAD
    Looks very cool.I like using Ionia's holey stuff too.
    But I do have a question.
    Why have a open driveline when your are using a early Ford trans
    and a banjo rear end,
    Why not keep the simple torque tube?
    Just wondering..
  14. el Scotto
    el Scotto
    from Tracy, CA
    Wow..... That is absolutely stunning!! Everything I'd want in a hot rod chassis and then some!
    Dang!!
  15. cball
    cball
  16. Beef Stew
    Beef Stew
    from So Cal
    I have a question... I'm building a similarly styled front end and I'm trying to figure out the best way to mount the radiator when there isn't cross member over the front axle. Your setup is the second I've seen where there is just a little 90 tab on the end of each frame rail and I can only assume that's where the radiator mounts. Is that all you're using to mount the radiator? The other car I saw that was like this was built by Ken and Keith so I can only assume it works because those guys obviously drive the shit out of their cars.
    Also, the tabs look a little higher up than the top of the frame rails. What are you going to use for a radiator?
    Thanks!
  17. patina steve
    patina steve
    Some one asked for a couple of pictures of the clutch and brake pedal area,also here's a picture of the Brookville body Bob is putting on the chassis
  18. patina steve
    patina steve
    The radiator mounts are very close to the same the Rolling Bones Guys use , The radiator is 2" shorter then stock
  19. langy
    langy
    Very cool frame :)
  20. JeffreyJames
    JeffreyJames
    from SUGAR CITY
    This one sits a little higher then the Bones cars and that may or may not be because of the engine weight not being there but I like the way it sits right now.
  21. JeffreyJames
    JeffreyJames
    from SUGAR CITY
    I know you are not talking to me.:D:D
  22. 3wLarry
    3wLarry
    from Owasso, Ok
    I'm sorry to throw a wrench in your thread, but I bought a Rolling Bones chassis for my 3w, and with the lengthened front shock arms, the shocks don't work like they are supposed to...not enough travel at the shock to dampen.
    The front end bounced around alot. I'm friends with the Rolling Bones guys, and I'm not putting them down, but the shock arms need to be shorter(as in original length) like Henry designed them, to work correctly.
    I understand the reason why they located the shocks inboard where they did...the frame is too narrow to move the shocks forward any more than they are...hence the lengthened shock arms.
    The solution is to mount the shocks on the outside of the frame where they were in the beginning using stock shock arms.
    The shocks were mounted inboard to clean up the frame for asthetic purposes.
    Ken Schmidt stopped at my house on his way back from California in Keith's coupe, and we found one of the lengthened shock arms broke in half. We took one of my shock arms off my coupe and put it on his so he could continue to New York....just my .02 cents
    kidcampbell71 likes this.
  23. slammed58buick
    slammed58buick
    Killer piece. Looks great!
  24. oj
    oj
    That is a pretty thing. Just how does the rear end articulate, like when one tire drops into a pot hole? Looks like the clevis' on the rear would bind up and something up front under that crossmember would have to rotate. And the whole rear is located from that same point, an area about 8X8". Looks to me when one tire drops into a pot hole the upper trailing arm would drop and have to get longer or something or else it'll act like a sway bar and try to lift the other tire. Have you played with this with a floor jack? Whats under that plate at the cross member? Can you take that off so we can see?
  25. moonlight graham
    moonlight graham
    from wyo
    Steve, No Snow yet in St. Paul?
    Geoffrey
  26. Looks great Steve! When will we see it on the road next year? Vintiques Rod Run in Watertown?
  27. Beautiful fab work -- and some good questions here, too. Thanks Larry for the insight on the shocks. Dennis Varni wound up changing out his shocks, too, when he got his Bones sedan back to CA.
    I've never seen a steering arm handled this way, welded to the spindle. Any fears it could bust loose?
  28. Malcolm
    Malcolm
    from Nebraska
    Very, very nice!! Thanks for the photos.
    Malcolm
  29. donut29
    donut29
    from canton MI
    Lookin good
    Can you post some more pix of the radiator mounts?
    Also is there a part# on the front spring or can you measure it for me. I'm working on a similar set up for my model A
    thanks
  30. Pewsplace
    Pewsplace
    Nice chassis, body and mock up. The piece of Art should not see a MN Winter. Keep posting pictures as work progresses.
    Thanks/
