Projects 32 Closed Cab Pickup Build
Discussion in 'Traditional Hot Rods' started by NealinCA, Jul 27, 2021.
  1. Blues4U
    Blues4U
    from So Cal
    I love it!
    Stogy and loudbang like this.
  2. Jack Rice
    Jack Rice
    Loving this! Great looking old pickup, can't wait for more! Thanks for posting
  3. The37Kid
    The37Kid
    Glad you are back, great Pickup, like the shiny 4Door. Nice to see there is a use for TT truck rear axle housings. Bob
    roddering, Carter, Stogy and 3 others like this.
  4. luckylou
    luckylou
    from canada
    Aweome build
  5. continentaljohn
    continentaljohn
    Cool truck and awesome build .. so the old motor was a 8ba with a wide belt but don’t see a fan? What motor will you be running? The reason I ask is I am building or putting back on the road a 32 truck with a 53 merc motor
  6. sko_ford
    sko_ford
  7. NealinCA
    NealinCA
    The Transition belongs to my son. I am old hardtail guy...currently on this steel Ragley 29'r
    Now back to hot rods. I did some trading with my brother and he rebuilt me another 39 trans, this time with 16/28 Ford gears...
    I also gathered up all of the front suspension pieces, made necessary repairs and sent them off for blasting and semi-gloss black powder coating
    More to come in the next few weeks...
    Runnin shine, Tman, Graham08 and 17 others like this.
  8. The37Kid
    The37Kid
    First time I've seen treads masked on Powder coated parts, What do they use that is flame proof?
  9. NealinCA
    NealinCA
    It's some sort of tape, but they always remove it before parts are picked up, so I'm not sure what it is. The shop I use does a lot of early Ford parts, so they know what to mask. Makes it nice.
    Hamtown Al, Stogy, Tim and 3 others like this.
  10. manyolcars
    manyolcars
    Neal, as always, you do First Cl*** work. I think about your GMC grille moustache turned into a 32 Ford radiator shell frequently.
    Just Gary, Stogy, loudbang and 4 others like this.
  11. You might want to be a little more careful where you park that heap in the future, could get expensive ;)
  12. NealinCA
    NealinCA
    I am putting a 59AB in this pickup, but did an 8BA in the patina Fordor. I used wide belt truck pumps, a 39 standard type pulley on a 12V 8BA style generator with a 35-36 fan. See pic below...
  13. A Boner
    A Boner
    As always...fantastic!
    Care to share and tips on how you achieved the white-ish paint finish?
  14. NealinCA
    NealinCA
    I scrubbed the whole truck with this. It really brought back what light blue/grey paint was left. I had some semi-gloss paint mixed to roughly match, that I have been painting any replaced parts or repaired areas.
  15. A Boner
    A Boner
    Thanks Neal! Beating back the light rust a little, and adding some paint to help preserve the metal, seems like a great idea to me! The not too ruff around the edges look, is an added bonus.
  16. 38Chevy454
    38Chevy454
    Nice work saving and rebuilding the original parts. Plus your small upgrades along the way. Truck looks like will be a lot of fun to drive around.
  17. continentaljohn
    continentaljohn
    Thanks for the info Neal very cool truck
  18. Tim
    Tim
    from KCMO
    Lookin good
  19. dumprat
    dumprat
    from b.c.
    Any idea what the battery tray I should out of? I got a twin to it from an estate sale.
  20. hotrodA
    hotrodA
    That looks great! What is the wide belt crank pulley? Thanks!
    loudbang, Stogy and kidcampbell71 like this.
  21. joel
    joel
    I like your bucking fixture and the way you repaired the wishbone mount. No shiny paint huh? Still, it's a nice truck .
    loudbang and Stogy like this.
  22. NealinCA
    NealinCA
    It was on the truck, but ***umed it was just an aftermarket auto parts item.
    49-52 truck, with the second groove machined off, so it would clear the crossmember better.
    loudbang, dumprat and Stogy like this.
  23. Bigmac48
    Bigmac48
    from Dundalk Md
    Love the attention to detail, the quality of the mechanical work like the 39 trans upgrades ,changes on the flatty truck water pump pulleys etc. Sweet truck and love your shiney 4 door with the burgundy wheels . Enjoy the fruits of your labor !!!
  24. Stogy
    Stogy
    What a great Thread...an admirable sprucing up to a capsule from a time not so long ago...thanks for sharing the adventure...
    loudbang and brady1929 like this.
  25. 32 Ford pickups make no sense. Many of us have owned them. There isn't much space. But they have the hot rod appeal that many desire. :) It's also the most affordable mode to a steel 32 Ford. The magic that it has lasted for decades. With that in mind, Neal, I'm sure you will make a great rod out of this. You're off to a good start. :)
    deucepickup32 likes this.
  26. louisb
    louisb
    Tag! Cool pick me up!
    --louis
  27. NealinCA
    NealinCA
    Didn't get much accomplished on the pickup, as I was at the local fair watching my daughter's FFA livestock compe***ions.
    I did do a wheel and tire swap with my Fordor, as I wanted to see what the maroon Kelsey's would look like on the closed cab pickup.
    The Fordor got the Lincoln Zephyr wheels and caps...
    So I could try these out on the pickup...
    The 3.54 rear end is about done, just need to run brake lines.
    I did just buy one of these tubing straighteners, so I can use bulk rolls of tubing. The local auto parts store are only carrying the green tubing. While easier to work with, I don't care for the look.
    Until next time...
  28. hotrodA
    hotrodA
    Thank you!
  29. joel
    joel
    I think the Kelseys look good. Are you going to remove leaves from the rear spring? any idea how many?
  30. NealinCA
    NealinCA
    I have it set up with 8 leaves, reversed eye main leaf and 41 shackles. I've done the last 2 cars that way and have been happy with the ride height. We'll see how it works out on this one.
