'32 Coupe Floor
Discussion in 'The Hokey Ass Message Board' started by metalshapes, Dec 28, 2006.
  1. metalshapes
    metalshapes
    First I took some measurements off the trunk floor in my own 5W, so I could copy the pattern.
    Then I made a new tool for my Pullmax to put the heavy beads into the Sheetmetal.
    The smaller beads are done with my Beadroller.
    I used the same pattern for the divider between the p***enger compartment and the trunk ( where the Gastank and the Battery will sit )
    And also for the Floor in the P***enger compartment itself..
    ( that piece is not welded in yet )
    I had to make some filler pieces to cover the Frame Rails, since this car is Channeled.
    And I decided to weld a Ford logo into that.
    ( I cut that out of a 351C Valvecover...)
  2. twjoyce
    twjoyce
    WOW, Alex, Looking GREAT !!!
  3. metalshapes
    metalshapes
  4. TimDavis
    TimDavis
    The real question here, I think, is did you have your ****ies on when you were doing this work?
