Technical '32 crossmember in a '34 frame
Discussion in 'Traditional Hot Rods' started by rmartina, Dec 2, 2017.
  1. rmartina
    rmartina
    will a '32 cross member fit a '34 frame? I'm missing the cross member in my '34, can find lots for a '32, looks like they would fit my boxed frame, but no one gives measurements in their ads
  2. sloppy jalopies
    sloppy jalopies
    the '33-'34 grill shells are wider than the '32s, but they both fit against the inner edge of the frame horns about the same so the frame horns must be wider by the difference in the grills...
    check westcotts auto restyling for dimentions...
  3. dumprat
    dumprat
    from b.c.
    The wescot dimensions don't help much. They don't use the same dimension references.
    Now if somebody had a 32 and a 34 they could measure from outside to outside at the spring centre that would be awesome.
  4. Runnin shine
    Runnin shine
    Do you mean “32” generically speaking? As in a 32 speedway, SoCal, etc, etc, 1” drop “model A” style? I think yes with you can work it out with boxed rails. If you mean stock 32, ehhhhhh, maybe not so much. Might be fun to watch.
  5. krylon32
    krylon32
    from Nebraska
    I've done a couple 33/34 customer ch***is with a 32 front cross member at the customers request. You have to fab some radiator mts in front of the cross member if you want to mount the radiator in the stock spot. The deuce cross member lowers the front more than the stock style repro 33/34. Both these ch***is were for very modified cars.
    Runnin shine likes this.
  6. dumprat
    dumprat
    from b.c.
    IMG_1613.JPG Outside to outside on my stock 34 frame is 27 1/4". Wescotts has the 32 frame at 25 3/4" at the same point, right at the centreline of the axle.
    Maybe the best way would be to use an A crossmember ment for an inboxed frame?
  7. Front, rear or center crossmember?
    Charlie Stephens
    LOU WELLS and Runnin shine like this.
  8. MR CLEAN
    MR CLEAN
    rmartina,
    Please see measurements of front cross member on my stock 32 and 34 Ford Frames below.
    MR CLEAN
    32 Frame 25 1/2
    34 Frame 28 5/8
  9. WTF really
    WTF really
    I'm pretty sure I have a 34 front crossmember I'll check it out today
  10. WTF really
    WTF really
  11. WTF really
    WTF really
    Well it's marked 34 I'm not positive that's what it really is.
  12. 32Dan
    32Dan
    from Chino, CA
    Cl***ic Street Rod Manufacturing in Ontario Ca might have something new you can use. They build model A, ‘32, and ‘33/34 frames exclusively.
  13. dumprat
    dumprat
    from b.c.
    Mr clean
    Your 34 ford frame looks to be spread. Mine is tight and original and is an inch narrower.
    And the crossmember certainly looks 34 and is only 27" wide.
