32 dash ???
Discussion in 'The Hokey Ass Message Board' started by sawbuck, May 24, 2010.
  1. sawbuck
    sawbuck
    from 06492 ct
    are the 32 car and truck dash the same size....also do the bolt holes line up....thanks sawbuck
  2. doctorZ
    doctorZ
    5 window, yes. 3 window no. (i'm pretty sure). the 3 window dash has a glove box. the dash inserts are all the same.
    can someone verify?
  3. HOTRODPRIMER
    HOTRODPRIMER
    I don't think the Truck and 5-window coupe share the same dash,,but I could be wrong. HRP
  4. ken1939
    ken1939
    Roadster/Phaeton same. 3 Window its own.
  5. chickenridgerods
    chickenridgerods
    from DSM, IA
    The closed cab commercial dashes (truck and panel delivery) are unique to the closed cab commercial vehicles. Open cab commercial (RPU), open p***enger car (roadster and phaeton) and 3-window coupe dashes are unique to those individual body styles. The remainder are interchangeable.
  6. Standard32
    Standard32
    from LA
    truck dash will not fit in a 5w or sedan...the truck dash is a little wider I think...
    3w dash is completely different...
    I think the inserts are different too... the distance from the firewall to the dash (on a truck) is not as much as a car...
    so a truck insert will not interchange with a car...
  7. 55 dude
    55 dude
    check with the folks at the new fordbarn.
  8. sawbuck
    sawbuck
    from 06492 ct
    thanks all...
  9. krylon32
    krylon32
    from Nebraska
    Truck dash is wider than the 5 window/sedan/vicky/4 dr. Truck dash works great in a 30/31 A.
