32 Delivery
Discussion in 'The Hokey Ass Message Board' started by FantaC, Mar 1, 2008.
  1. FantaC
    FantaC
    from Australia
    I want to build a 32 Delivery
    I have some ch***is rails lined up
    I need some pics , measurements and advice
    Any help would be appreciated
    Thanxs John Gilbert
  2. 29bowtie
    29bowtie
    Get some ideas from these works of art. Not my pics,they're off the HAMB.
  3. cabriolethiboy
    cabriolethiboy
    Built mine out of a Tudor 22 years ago. Used a Gibbon door, but when it gets rebuilt it will have a steel door. Be sure to brace the inside of the body because when you take the center of the body out in the rear you lose some of the lateral support. Mine is cracking outwards from the corners of the door jamb(rear door) from the flex in the body. If you look close you can see it in the pic. You need to put some diagonals from the top of the door jamb to as far out as you can to the sub rails. Also some gussets on the bottom where the door jamb meets the sub rail would help too.
  4. Pewsplace
    Pewsplace
    Here are some photos of my friend George's project delivery. He purchased a kit from a fellow in Kansas. This is not a cheap deal unless you do it all yourself. This is a first cl*** conversion done by Jim Hendricks in Northern California.
  5. studematt
    studematt
  6. FantaC
    FantaC
    from Australia
    Thanxs Guys
    they all look Awsome
  7. hey john
    have you seen this one around perth?
    seems to get around a lot
  8. FantaC
    FantaC
    from Australia
    no i hav`nt seen that one J
    You guy`s might larff at me but i want to hand make the complete body
    I will be using a 3d program to design it so i need some good side , front rear pics
    A friend will let me make templates from his 32 pickup cab so i will start from that
    thanxs again for all your help
    John Gilbert
  9. FantaC
    FantaC
    from Australia
  10. tommy
    tommy
    That's a panel truck and not a delivery.
  11. 32 pickup cab is nothing like a 32 sedan. More like a Model A. You really need to locate a 2 door sedan and take your measurements from it.
  12. FantaC
    FantaC
    from Australia
    Thanxs for your reply`s
    i want to build it for my buisness ( mobile rust repairs )
    it will be used to carry my tools around so i might have to make the panel truck instead but with the rear end of the sedan delivery . Drop the body over the ch***is and a mild chop top
    thanks again for your help
  13. panhead_pete
    panhead_pete
    Hey John why not go measure Plodges?
  14. FantaC
    FantaC
    from Australia
    Thanks pete
    i just called him
    and he said no problem i can make some templates from his car
  15. FantaC
    FantaC
    from Australia
    so far i have been offered a 32 pickup cab to copy from
    also a 32 tudoor to copy the side panels from
    but it will be a bit longer so it will cover the rear ch***is
    I want to drop the body down to cover the ch***is rails and a mild chop top
    it will have fenders and hopefully a Jag diff
    <!-- w -->
  16. FantaC
    FantaC
    from Australia
    How different are they ?
    wich one would look better ?
