Technical 32 fender braces
Discussion in 'Traditional Hot Rods' started by Langan, Dec 31, 2014.
  1. Langan
    Langan
    from Eagle ID.
    Got a set of Brookville front fenders and braces. Braces don't seem to fit well. Not conforming to fender curve. If I make them conform then end of brace seams not to go far enough arounder to bead.
    Is there any threads or pictures of how they should fit
  2. krylon32
    krylon32
    from Nebraska
    Nothing fits like the originals. I have tried the repops and have ended up cutting them just beyond the headlight bar mounts. I know that somewhat defeats their purpose but my 2 FF cars are so low I needed the clearance. I've done this on several FF cars and have experienced no problems to date. I also like it because it eliminated the bolts thru the fender.
  3. captain scarlet
    captain scarlet
    from Detroit
    The repos don't fit for*****.
    The only thing I've found that works is original parts. Last pair I brought cost me about $50
    Singlefingerspeedshop.com. Detroit
  4. Dennis D
    Dennis D
    On my F/G fenders for my F/G car I found I had to cut the repro braces in three pieces and form them to fit and then weld them back together. Piece o' cake. :mad: Dennis D
  5. wuga
    wuga
    When you spend that kind of money, don't you think you should be talking to Brookville?
    wuga
  6. Langan
    Langan
    from Eagle ID.
    Thanks for confirming what I thought. Krylon I to plan on low ride hight. When you say you cut just past headlight bar does that mean there is no brace past headlight? Or did you thin it out and weld to elimanate bolt? Happy New Year
    I do not think Brookville much cares if they fit.
  7. krylon32
    krylon32
    from Nebraska
    There is no brace past the headlight. I've driven several fendered cars like this many thousands of miles and had no problems with the fenders. My 3 window has a little more than an inch between the tires and fender so end of the brace had to go.
  8. Langan
    Langan
    from Eagle ID.
    Thanks this help a lot since I moved the center of tire forward 3/4 of an inch tire would have for sure hit. My 34 truck I was able to make sit as low as you are talking about but the 32 is harder to get that low? I think because the 34 frame is higer in front?
  9. Langan
    Langan
    from Eagle ID.
    4" drop axle, notched frame and raised cross member. To much to chang to 5" drop now
  10. krylon32
    krylon32
    from Nebraska
    On my own deuces I always move the crossmember ahead 3/4 of an inch over stock seems to center the wheels just a little better in the fenders.
    32SEDAN likes this.
  11. Langan
    Langan
    from Eagle ID.
    Thanks for all the help you always have good advice
  12. OzyRodder
    OzyRodder
    I got my braces from C&G and they fit my original fenders fine. A bit of alignment work but worked out. I left the braces loose at the chassis and then bolted in the headlight bar followed by the coach bolt at the fender edge. Then tightened at the chassis and all good.
  13. Langan
    Langan
    from Eagle ID.
    Thanks I will check them out..
  14. pitman
    pitman
    The Model A's had a cast version, followed later by a stamped steel channel type.
    I recall having to apply a Stilson wrench, to make a number of bend adjustments, then
    finally align the outer fender bolt. Deuce would seem similar in method?
    Then there are mt. base-shim, and elongated headlight bar hole tricks!
  15. Langan
    Langan
    from Eagle ID.
    I get it I have fenders where I want them-now I will cut,bend beat the braces till they fit. Kinda what I though just real good to here from you guys had to do same.
  16. we made braces from flat 1/4 strap. Made patterns of the fender profile then heat and bend.
    weld a 3/16 tube next to the bracket to hide the head light wires
    these allowed for a super low profile
  17. greg32
    greg32
    from Indiana
    Worked with original and repop braces. I made mine follow the contour of fender out past headlight bar mount. Stock, they run flat more or less toward edge of fender. Have to do this for tire clearance if you want it low. As you said, doing this they end up short at the fender edge. bolt hole ends up about an inch or so too high, not right above fender bead. I cut end off just above flat and sectioned in a slightly longer end from another brace.
  18. Langan
    Langan
    from Eagle ID.
    Thanks great help. Clears up a lot.
  19. Pewsplace
    Pewsplace
    All the more reason to FTF! (Forget the Fenders)
  20. Langan
    Langan
    from Eagle ID.
  21. Langan
    Langan
    from Eagle ID.
  22. 325w
    325w
    Thought the 32 had a right and left?
