Projects 32 Five Window highboy
Discussion in 'The Hokey Ass Message Board' started by koolbeans, Dec 30, 2018.
  1. koolbeans
    koolbeans
    Thaaar she be....off the table for the last time (hopefully)....scooting but no tootin yet....motor/trans today????? IMG_20190802_095225578.jpeg IMG_20190802_095210785.jpeg IMG_20190802_095052054.jpeg IMG_20190802_095031517.jpeg IMG_20190802_095006280.jpeg IMG_20190802_094809452.jpeg
    Sent from my XT1710-02 using The H.A.M.B. mobile app
    pivir123, Thor1, Vic Walter and 4 others like this.
  2. Shadow Creek
    Shadow Creek
    I have a question on the cantilever/rocker suspension... it appears the arms of the rockers are equal length, if this is the case do you calculate spring rate the same as if they were mounted vertical? Just trying to learn a little, I haven’t been able to find any calculators for figuring spring rate on a cantilever suspension
  3. koolbeans
    koolbeans
    Big do today...off table, on it's feet, and Ardun and trans install....whew yeeee haaah.....
    Items like plastic setup Ardun heads/block, build table, 200r4 dummy trans, 351w plastic block and lots of other fabrication stuff will be posted for sale as Last Hurrah Garage winds down. (Inventory list available via text or e).
    I can smell the roses..... IMG_20190802_152759841~2.jpeg IMG_20190802_152925704~2.jpeg IMG_20190802_153159398~2.jpeg IMG_20190802_152956561.jpeg
    Thor1, Vic Walter, loudbang and 3 others like this.
  4. You bet your sweet biscuits.
    What a rig.
    The benefits of coilovers without the space intrusion is neat.
    And in the rear view, the rear axle almost looks like it's not even attached to the ch***is.
    Fun to watch all the finished components come together.
    Top drawer, KB.
    Sent from my VS835 using The H.A.M.B. mobile app
    Thor1 and loudbang like this.
  5. koolbeans
    koolbeans
    Vic Walter, charleyw, 54reno and 4 others like this.
  6. alchemy
    alchemy
    Why go to all the trouble to hide the coilovers in the rear, then have those bright yellow coils sticking right out front?
  7. koolbeans
    koolbeans
    I love your quick wit. There will be a color change. Didn't want to paint them yet as I rekon there will be a spring rate change when all the other goodies are installed.
    Tman, Kiwi 4d and loudbang like this.
  8. koolbeans
    koolbeans
    Oh by the way....serious thought given to hiding front suspension all together. But I got way down the road with mono leaf spring and hit a wall. 5" dropped axle, model A cross member, and a 9" deep Ardun oil pan got me in trouble. To maintain 4-5" ground to a bazillion dollar cast finned oil pan had to push the motor upwards while dropping the frame to get stance. Huh, then the monoleaf spring clamp crashed into the cross member. Urg. So abandoned the mono leaf. Then quarter eliptics, no, then sprint car torsion bars, no. A frame suspension ×π√÷% no.
    Fall back to been there done that..I-beam, coilovers, split wish bones. Oh well......m
    Tman and loudbang like this.
  9. Andy
    Andy
    I need to post pics of the fibergl*** monoleaf springs I used to make. They rode great and set extremely low.
    My supplier cut me off.
  10. figure8
    figure8
    Wow! love that ch***is.
    Fordor Ron and loudbang like this.
  11. Atwater Mike
    Atwater Mike
    I'd ride on windbags before trusting another monoleaf...=Snap!= 1.5 years, then one morning? 2 blocks to the corner, =Snap!=
    Surprised me, as the '55 F100 made a quick 'right'. But my lightning fast reflexes brought it back around...stopped, but...Had to back up all the way back to the house! :cool:
  12. koolbeans
    koolbeans
    Lightening fast is the "operative" activity here.....
    King ford and loudbang like this.
  13. koolbeans
    koolbeans
    Moving along.....couple jabberwockies to address, but carbon monoxide is just around the corner..... IMG_20190810_113119680.jpeg IMG_20190810_112048940.jpeg IMG_20190810_113504023.jpeg
  14. Mike Colemire
    Mike Colemire
    That thing is coll as hell, even the big yellow coil overs!
  15. koolbeans
    koolbeans
    Ok, ok, ok......yellow is temporary. Will paint them very soon. Maybe tonight. Rate change needed....will change to....?
    loudbang and Thor1 like this.
  16. Andy
    Andy
    The original spring was about 125#/in side
  17. koolbeans
    koolbeans
    Andy, can I then ***ume from arch to flat was about 375lbs.
  18. koolbeans
    koolbeans
    Chipping away...Rootlieb 2" extended hood fitted. Pleased
    Hood sides in hand, fitting next. Lots more work in them since blisters for heads will be a challenge....till next time.. IMG_20190812_100741554.jpeg IMG_20190812_100500524.jpeg IMG_20190812_111224416.jpeg
  19. Andy
    Andy
    I hate to see it but there may be trouble ahead, The sides will have to swing out to be raised due to the blisters. The shock towers will prevent this. I have blister side panels for my 32 roadster.
    Maybe have fixed panels behind the shock mounts and let the rest move out and up???
    Have you seen pics of **** Smith's hemi roadster in the Ford Museum? He cut out his side panels to clear the covers.
    loudbang and koolbeans like this.
  20. deucendude
    deucendude
    from norcal
    I know I will hear about this but, too much mix of old and new parts.
    Hutkikz, lurker mick and WiredSpider like this.
  21. koolbeans
    koolbeans
    You're ok with me. Original Henry body and interior, I mean original. Ardun, Winters quick change, wishbones, I beam axle, kinda a preservation, but with auto, air, electric leather buckets, a few other trickeries.
    At 76 and all joints replaced plus a few other s***chie tattoos....I reckon a couple of soft touches are allowed......no.
    Shamus, loudbang and HemiDeuce like this.
  22. koolbeans
    koolbeans
    Well done this before. Sides sit on pins in the frame, then held at top with ****on latches. (Kinda like a zues). Run with or without.
    Top of hood is center hinged. Run with or without.
    No troubles.
    Shadow Creek, brEad and loudbang like this.
  23. koolbeans
    koolbeans
    Spell check ****s....
  24. Piewagn
    Piewagn
    When I initially saw the mock up of the rear coil overs, my first thought was "race inspired". I love the way you tucked them up and the quickchange keeps that traditional look. All part of that coloring book. This build in inspiring Sir and it makes me want to thrash even harder! But, can't go too hard, the body breaks down if I do..... Fine machine.....yes Sir!!!
  25. koolbeans
    koolbeans
    40 roger on the bod. 100 degrees, 100 humidity here.....76 clicks really wearing down. My head way ahead of activity. Gonna take 30 till cool and rest for the finish.
    Love your build.
    loudbang and Piewagn like this.
  26. Piewagn
    Piewagn
    Thank you Sir! Headed to Virginia for a week to see family, hopefully come back refreshed! Looking forward to hear that Ardun! Enjoy your respite!
  27. deucendude
    deucendude
    from norcal
    O K, you win. Nice build!
    Atwater Mike and koolbeans like this.
  28. It looks awesome,,,you are very talented!
    But,,,,why hide that beautiful Ardun?
    Tommy
    m.ralph, loudbang and koolbeans like this.
  29. koolbeans
    koolbeans
    Actually, I won't. Sides/blisters will be an exercise. Hood tops held down by leather straps most of time.
    The core/purpose of the build is to showcase/feature the Ardun in '32 Ford five window clothing in highboy form. (fenders?....in some form later).
    The motor in its simplist form is the star. Nothing radical. Just plain jane...
    The over all end product...not open check book high end...all the stuff is off shelf ready available catalogue items, pretty much bolt together, nothing radical.
    I chose the original donor car cause l liked the color, (minimal paint, no body work), liked the interior, (ol school), (lots of $$ savings and huge time savings).
    Net....done quickly (about 28 weeks clock time, about 9 month calendar time). At 76 time to ride is important. Plus I love to doing this stuff. Fun, fun....
    Shadow Creek and loudbang like this.
  30. koolbeans
    koolbeans
    Ah, me from Virginia for Lovers too.
    CO from Ardun hopefully soon.
    Have a good one too.
