32 five window seat copy
Discussion in 'The Hokey Ass Message Board' started by rexrogers, Oct 13, 2009.
  1. rexrogers
    rexrogers
    Just though i would p*** this along it is a stock style seat for a 32 Ford 5 window. this seat was made in house and retains the stock dimensions and style just not the price of an original seat. It is straight forward seat that will get you on the road, we made three in the shop and i have one left over if any one is interested in it, and or this seat can be readily made with in anyones own garage.
    www.realhotrods.com
    Rex Rogers
    Custom Auto
    1067 Des Moines Ave
    Loveland, Colorado 80537
  2. BCR
    BCR
    Man, That looks nice.
  3. brady1929
    brady1929
    looks great, are you offering plans?
  4. rexrogers
    rexrogers
    Still needs the sliders put in and a seat bottom made the rest is up to the upholster.
    I can post some of the measurements if you want.
    Rex
    www.realhotrods.com
  5. brady1929
    brady1929
    that would be great! i have seen your work on metalmeet.com and you are very talented. did you roll the edges on a bead roller?
  6. rexrogers
    rexrogers
    Since we made enough side to make three seats a quick hammer form was used to help maintain accuracy on the finished edge. If you are only making one seat the wire edge can be put in with nothing more than a few hand tools and the rest of the seat is rectangle tube and plywood. once these seats are covered they look like a stock seat.
    The Base Dimensions are 19" deep 38" wide at the front, and 39 3/4" at the back edge of the seat. The plywood back is 26 1/2" tall 39 3/4" at the bottom and 45 3/8" along the top edge the top edge has about a 3/4" rise through the center. the metal side near the plywood stick out 5" or so, the lower is almost 4" up from the base.
    I hope this is of some help to anyone
    Rex
  7. rexrogers
    rexrogers
    For seat sliders you can order a set from almost any parts catalog. Fabricate a few mounts off the base put the seat at the angle you want and height.
    Rex
  8. willysguy
    willysguy
    from Canada
    Thanks for sharing the info, good stuff. Looks like some nice 3 windows on your site!
  9. mustangsix
    mustangsix
    Rex, that is so awesome in its simplicity! Can you shed any light on how the cushions will be fabricated?
  10. Dirty2
    Dirty2
    Nice ! Thanks for posting .
  11. rexrogers
    rexrogers
    A seat bottom will be made out of 3/4" plywood and held in place with two guide pins off the base just like a stock Ford seat. The rest we let the upholster carve the seat out of foam this allows him the opportunity to make the seat fit the customer exactly.
    Rex
  12. rexrogers
    rexrogers
    Here is a similar seat for a 32 3 window they are a little different than the five window seat a little larger and more wood in the construction of it just like the rest of the car this seat has the slides in and the seat base is made with the guide pins
    Rex
  13. fordcragar
    fordcragar
    from Yakima WA.
    Very nice, thanks for sharing.
  14. willysguy
    willysguy
    from Canada
    Rex, just thought I'd bring this back up. Dose the upholsterer use a webbing on the bottom ? Would you happen to have dimensions on a 3 W seat?
    Thanks Duane
  15. Royalshifter
    Royalshifter
    Moderator
    Rex those are sweet seats for the cheaks.
  16. thisbugger
    thisbugger
  17. Thanks for the info Rex. I will be making one for my 3 window...I could also use the dimensions....
  18. Never did see a price or if they or parts were for sale. I'm sure there would some interest in the welded bottom and sides and would be inexpensive to ship, (if sides not welded to bottom yet) most all can do the woodworking part. If metal parts were for sale, price? Thanx, Dave
  19. hajboj
    hajboj
    from Long Beach
  20. McFly
    McFly
    Cool...I will have to try this out! Thanks Rex.
  21. Pewsplace
    Pewsplace
    Rex, nice work as usual. I saw one in a sedan at Columbus that someone made that I liked. How did you bend the rectangular tubing for the corners? Maybe you made this one for the sedan.
  22. Rags To Richs
    Rags To Richs
    Great Thread.... Im currently rebuild my 32 ford Hiboy Roadster and this will come in handy in the near future.....
