Projects 32 Ford 3 window FIND
Discussion in 'Traditional Hot Rods' started by 383deuce, Mar 29, 2014.
  1. big duece
    big duece
    from kansas
    Yea, it could be. Probably not so much with the jack used also.
  2. David Gersic
    David Gersic
    from DeKalb, IL
    Yep. I'd put it on the other side where it can't slip out.
  3. Runnin shine
    Runnin shine
    If the axle was dropped I sure as hell wouldn't creeper my way under there!
  4. 383deuce
    383deuce
    Hey guys the only reason it was there was when I put it on the inside it made it hard to get a good look at the head light bar and that is what I was trying to show him. No work under the car was done with it in that location.
    hipster, wedjim and Runnin shine like this.
  5. Runnin shine
    Runnin shine
    OSHA you may return to base camp, move along.
    hipster likes this.
  6. so_dak_kid
    so_dak_kid
    Dennis, did you install the top insert or have the Upholstry shop do it? I'll be crossing that bridge at some point with my coupe as well.
  7. 383deuce
    383deuce
    so-dak-kid,
    I installed it and it was a ***** due to the 42 small bolts that attach it to the top of the car. Metal top has a covering of about 1/8 inch very dense foam (like is used under a vinyl top) then re spray with 3M glue and attach the hartz material. Cut small slits at all bolts and glue around underside.
    I trimmed the complete outer edge of the area around where the top goes with 2 layers of painters tape and then put one layer of gorilla tape over it to prevent any over spill of the sealer I installed around the edge, and to keep from nicking the edge with all the bolts when installing the top.
    I might say it is a 2 person job when you go to set in place though.
    catdad49 likes this.
  8. Tim
    Tim
    from KCMO
    Just found and caught up on this thread, had I known the story behind the car I would have looked at it closer as I sweat my face off at greaserama. I can however attest to it looking black in person in indoor lighting. Killer :)
  9. big duece
    big duece
    from kansas
    Looks like Dennis has his exhaust in and some small's. He might chime in to add more details. IMG_1393.jpg IMG_1394.jpg
  10. HOTRODPRIMER
    HOTRODPRIMER
    Beautiful job on the top insert and looks so much better than the Juliano's kit or the all too common filled top. HRP
    loudbang, 509garyd and Runnin shine like this.
  11. Malcolm
    Malcolm
    from Nebraska
    Car is looking great, Dennis!
  12. Just went through your entire thread again,
    the car has come so far, it looks great.
    I hope we both make it to Austin and get to meet as well.
  13. 383deuce
    383deuce
    HRP, Floweister & Malcolm, Thanks for liking what I am building. It has been a fun project for sure. Exhaust is at a stand still as I ran out of argon gas for the tig right after the above photos were taken. Got time at long last to make the 50 mile round trip to Lindweld to replace it so hope to get it done soon.
    HAPPY THANKSGIVING everyone...
    509garyd likes this.
  14. big duece
    big duece
    from kansas
    How did you fit the bottle of Argon in the roadster?
    Runnin shine likes this.
  15. 383deuce
    383deuce
    big deuce......I had to drive my pick-up truck. I would have rather drove the roadster, but like you say....How would I get the dam bottle of gas in the small trunk of it. Guess a guy can't have fun all the time.
  16. 383deuce
    383deuce
    Well the exhaust has been on hold as I ran out of 45's (bends) and had to order 5 more of them. I went to Summit as they had the best price on them I could find. Just received them today and boy am I impressed with the quality of these stainless steel bends. They make all the other SS exhaust parts I have bought look like ****. Now my problem is going to be making all the rest of the exhaust look as good as the new 45's.......
    509garyd, wedjim and loudbang like this.
  17. MR CLEAN
    MR CLEAN
    Touchdown!!!! Will enjoy watching your build. A original '32 Three Window......the Holy Grail of Hot Rods Congrats......
    509garyd and wedjim like this.
  18. big duece
    big duece
    from kansas
    Dennis wrote...."Well this is where I am at on the exhaust work. It is a lot of work
    fitting, grinding, re-fitting and then more fitting. The one small
    section on the drivers side going into the 45 took me 2.5 hours to get
    it to fit right. Everything is just spot welded at this time and I
    should have the drivers side done up and over the rear end tomorrow."
    here are some updated pics..... IMG_1394.jpg IMG_1399_1.JPG IMG_1400_1.JPG IMG_1401_1.JPG IMG_1402_1.JPG IMG_1404_1.JPG
  19. e z i
    e z i
    So *****in'... blue is the new black..
  20. big duece
    big duece
    from kansas
    "Well guys it is done at long last......
    Hope you like it......
    Dennis
  21. 383deuce
    383deuce
    With the exhaust done it was time to bleed the brakes & clutch, add fluid to the 5 speed. Was unsure how much fluid the transmission needed. Looked it up and it needs 2.8 quarts. Leveled up the 5 speed, removed the fill plug on the side and the shifter top to add the fluid through it as much better than trying to fill through the side.
    I could only get 2 quarts in it and it started running out the side plug. WTF......Checked with big deuce that built the 5 speed for me and it seems since this was a WC Camero transmission & they set at an angle & mine is now set square with the world the plug has to be installed and then add the remaining 3/4 quart.
    Never to old to learn......Won't be long now and the body will find it's home on the frame for the last time.
    Merry Christmas everyone
    rob lee and Flowmeister like this.
  22. wedjim
    wedjim
    from Kissimmee
    A little bit underfilled is better than a little overfilled. It tries to find its way out of seals if overfilled.
    I would set the trans level and go by the plug myself. 8)
  23. vintagehotrods
    vintagehotrods
    Dennis, it turned out great! Really like the way you routed the exhaust, clean and simple!
  24. big duece
    big duece
    from kansas
    The camaro gear box has the fill hole lower. Right in the casting web line. When its tilted, that fill hole is the same height as the s-10 is on level ground. The s-10 fill hole is ABOVE the casting rib. In this pic, its a camaro. The box has the casting boss for the s-10 also, but its not tapped and drilled. If it were used for s-10, the upper hole would be used if mounted level with the world. Every tech article if found states 2.7 quarts. 6533773_orig.jpg
    RODIST likes this.
  25. big duece
    big duece
    from kansas
    Only if you used a T5 trans that was designed to RUN level, you can do that. His camaro case is intended to be tilted in its original application. So, if that is altered , so is the way you fill it.
    RODIST and wedjim like this.
  26. krylon32
    krylon32
    from Nebraska
    Thanks, First time I ever noticed the difference. Never had the 2 of them side by side to compare
  27. The frame looks great!
  28. chevyfordman
    chevyfordman
    I hope you get to bring the car to the Mid West Deuces meeting next year, its usually warm and I would love to see the car in person. Do you live far from Lincoln? Great job on the car by the way.
  29. cully33
    cully33
    Looking good Dennis, hope to make it back over there one day and ride shot gun.
    Cully
  30. Runnin shine
    Runnin shine
    I'm pretty sure I called shotgun back on March 29th 2014 after post #1 was made.
