Projects 32 Ford 3 window FIND
Discussion in 'Traditional Hot Rods' started by 383deuce, Mar 29, 2014.
  1. David Gersic
    David Gersic
    from DeKalb, IL
    The electronic flasher should be working, that's the point of it. If it needs a bulb load, it's not working correctly. Whose flasher is it?
  2. 383deuce
    383deuce
    I can't tell you the brand name right now, but I bought it from Heinzman speed shop for around 30.00.
    Like everything else these days I see it was made in China. It did have the ground wire on it as some do not. From what I have been reading all LED tail lights are not the same. Some draw more or less than other brands with some requiring a inline dieode.
  3. 383deuce
    383deuce
    Ok all you motor experts out there I fired it up today for the first time and done the run in on the cam. By the time I was done with that the headers seemed hotter than they should be. Did a temp check with one of those temp guns and at the center 2 exhaust they were at 550 and the front and back exhaust at the headers was 300. Motor temp was only at 170 per the temp gauge and temp gun reading.
    The motor was pulling 4 lbs of fuel pres per the gauge. Motor sounded great, but I am concerned about the exhaust temp . I fired up my roadster with the same headers and the difference from the center 2 and the outside 2 exhaust was only 100. The center 2 was reading 350 & the outside 2 was at 250 and all this is at 900 RPM on both motors.
    WTF????????any ideas?
  4. OLDSMAN
    OLDSMAN
    This is still a fresh engine, make sure the carb isn't too lean, and put some miles on it before you get to worried.
  5. big duece
    big duece
    from kansas
    What do you have the base timing set at, and how much advance is built in the distributor? Were you able to check the total advance at 2500-3k? I too, agree with the fact that its new, and might have some temps a bit higher than normal. Too far retarded on the timing and it will run hot. Also make sure your vacuum advance is drawing from manifold vacuum, and not ported on the carb.
    loudbang and Runnin shine like this.
  6. 383deuce
    383deuce
    As far as the total advance at higher RPMS all I have is an old school timing light so no. Timing I started out at 8 degrease and moved it up to 10. Cam says 10 to 12 degrease.
    Please explain what you are saying about vacuum advance drawing from manifold vacuum and not ported on the carb?
  7. cowboyinachair
    cowboyinachair
    from colorado
    manifold vac goes full advance at idle port vac increases as you open the ****erflys i prefer port vac myself
  8. big duece
    big duece
    from kansas
    Each guy has his own way that thinks its best, but it will run cooler at idle, and better mpg at cruise with manifold vac to dist. can. At idle, your timing with manifold vac. will include base timing and what ever is in your advance can. Use an adjustable can, so you can dial in what you want. I am not going to start the dreaded ported/manifold vac. debate again.
  9. dirt t
    dirt t
    My experience with high exhaust Temps is retarded timing
  10. perrytudor32
    perrytudor32
    from uk
    you have private message,phil.uk.
  11. loudbang
    That is why the late model cars in the 80's & 90's had severely retarded ignition timing to meet the govs emissions standards and why running temps now in the 200's are common.
    kidcampbell71 likes this.
  12. OLDSMAN
    OLDSMAN
    Distributor advance should be ported vacuum, not manifold vacuum If it has manifold vacuum it will pull the advance to full advance once the engine is started. Ported vacuum will be from the carb one of the small ports, a vacuum gage will confirm what port it is. Manifold vacuum will probably be in the 16-18 inches of vacuum range at idle. Yes retarded timing can cause high exhaust temps
    Atwater Mike likes this.
  13. big duece
    big duece
    from kansas
    Please explain YOUR advantages of ported over manifold. Gm engineers started the ported system in the 70's to cut down on emission but engines ran hotter. You will not achieve "full" advance until your cruising with base, centrifugal, and vacuum timing will all be in. Most the the GM stock distributors had way too much in their vac cans. All aftermarket dist have adjustable cans for this reason.
    thunderbirdesq and loudbang like this.
  14. OLDSMAN
    OLDSMAN
    Manifold vacuum will get full advance way too soon, ported vacuum will get a slower full advance, so the engine will run better through the total RPM range
  15. 383deuce
    383deuce
    TOOK MY FIRST RIDE TODAY IN THE 3 WINDOW.....WOW!
    IT WAS A TOTAL BLAST IF I DO SAY SO........HAVE A FEW SMALL THINGS TO WORK OUT WITH IT, BUT NOTHING MAJIOR. TRACKS GREAT AND STEERS GOOD. BRAKES NEED SOME FINE TUNING AT THE REAR....
    NOTHING BLEW UP OR FELL OFF AND THAT IS A PLUS. EVERYTIME I DRIVE A FRESH BUILD I AM PUMPED TO THE MAX AND LOOKING FOR THE VERY WORST TO HAPPEN. THIS RIDE WAS EVERYTHING I DREAMED OF AND NONE OF THE BAD THINGS . IT RAN HARD AND PULLED VERY STRONG. CLUTCH COULD USE SOME MORE FINE TUNING, BUT LOVE THE 5 SPEED AND QUICK CHANGE. ALL IN ALL A GREAT RIDE AND A GREAT DAY.....
  16. big duece
    big duece
    from kansas
    Pufff, Blues4U, kidcampbell71 and 6 others like this.
  17. B1gDaddy
    B1gDaddy
    from aladambama
    Mighty fine Mr Mayor!
  18. cully33
    cully33
    Great to see it all come together for you Dennis, I think it will be a long time before that smile comes of your face.
    Your mate Cully
  19. 509garyd
    509garyd
    Congratulations Dennis, looks awesome...
  20. arkiehotrods
    arkiehotrods
    Looks simply Deucetastic!
  21. 2deuces64
    2deuces64
    Excellent!!!!!!!!!!!!!!!!!!!!
  22. 383deuce
    383deuce
    WOW! Thanks to everyone for all the great things you have said about this hot rod. It is really hard to think I started this build just a little less than 2 years ago and it has come to life. Seems to me it has been longer than 2 years.
    THANKS TO EVERYONE
  23. hotrodderhaag
    hotrodderhaag
    it looks killer. great color choice too! I bet the first ride was a blast . can't wait for mine ! keep the photos coming !!
  24. fonti
    fonti
    Dennis, congratulations!! so great to see how your dream car came together... remember when you showed me the body in this garage when you helped me fix the model A on the way to the salt? Have fun with your new toy!!
    hipster likes this.
  25. OLDSMAN
    OLDSMAN
    Now just drive the hell out of it and enjoy it all
  26. crminal
    crminal
    Wow, just took a look through your thread. Excellent work and the final product will be one to be proud of. Is this the car your referred to on the paint thread? Single stage enamel or poly?
    Still planning to rub through the paint in spots?
    Now I'm off the read the whole thread.
  27. krylon32
    krylon32
    from Nebraska
    Gotta give Dennis a big Atta Boy. 76 years old and still chasing the dream. He is someone we can all aspire to.
    The37Kid likes this.
  28. Jeff Norwell
    Jeff Norwell
    MODERATOR
    Nailed it!!!!!... great Hotrod Mayor.
    383deuce likes this.
  29. Deuce-Deano
    Deuce-Deano
    from Gilroy Ca.
    Great to see your out enjoying it Dennis, It sure came out FANTASTIC !!
    Going to be a fun packed summer of cruising for you.
  30. 383deuce
    383deuce
    Yes it is the car. It is single stage PPG and if you look at the photos of the paint taken in the sun light you will see where I have sanded through in lot's of places. In the low light you don't see it that much and the car looks black, but in the sun light you can really see it and the blue comes out.
