32 FORD 5 W SOLD
Discussion in 'Cars For Sale' started by webb1932, Jan 13, 2020.
  1. webb1932
    webb1932
    City: athens
    State: Tennessee
    Price: $39500
    Very good fit and finish. BeBops body. Dyna-matted. Doors and trunk close as they should,firm,solid and with excellent gaps. Black base coat-clear coat with custom pin stripping.
    -Power windows
    Vintage air and heat
    Walker Rad. with Cooling Components fan & shroud
    Polished Ididit tilt column
    40 ford steering wheel
    Rootlieb louvered hood with Brookville rad. shell and insert
    Auto Meter white face gauges
    Bench seat,adjustable fore and aft as well as recline adjustments
    AGM battery
    Manual brakes
    Lokar shifter and brake pedal
    Sun tach
    Pioneer CD/media player with rear speakers
    TCI chassis with 4-piston front brakes with polished backing plates and So-Cal scoops (scoops not functional but could be)
    Chrome front end,dropped axle leaf spring, hair pins etc..
    Vega steering box
    Currie 9" rear with 3.55 gears and 11 x 2.5" rear drums
    Chrome rear coil-overs and sway bar
    ZZ 4 crate engine from Chevrolet Performance with TH 350 Trans. Finned aluminum oil, trans. and flywheel cover.
    Has GM "Hot cam" in engine as well, similar grind to the ZZ 430 setup as I understand. Lots of time making sure this car drives the way it should, we drive all our cars and have little to no patience for one that has issues.
    Just a few of those things:
    Proper 7 degree front caster
    Proper drive-line angles to insure long life and no vibrations
    proper steering rod and relative pitman arm angles to insure smooth easy steering and to prevent premature wear
    Factory style Rubber engine and trans. mounts for smooth operation
    Rear sway bar to reduce body roll
    Titled as '32 Ford. Clear title in my name
    Would consider trade for '32 Roadster or '32 2 dr. sedan. Calls or P.M.'s only- no texts.
    423 507-3503 cell or 423 744-7496 home Ask for Bill
  2. webb1932
    webb1932
    btt
  3. webb1932
    webb1932
    btt
  4. webb1932
    webb1932
    PRICE DROP Need to start on new project. $37500
  5. webb1932
    webb1932
    Still Avail.
    newalla 33 likes this.
  6. webb1932
    webb1932
    still avail.
  7. webb1932
    webb1932
    Still Avail.
