32 Ford axle question
Discussion in 'The Hokey Ass Message Board' started by harleycontracter, Feb 21, 2013.
  1. harleycontracter
    harleycontracter
    Is there a front and a back to an original 32 Ford axle?
    Put my front end together . Sitting on the floor it doesn't look right.
  2. metal man
    metal man
    No front or back. What exactly is the problem?
  3. harleycontracter
    harleycontracter
    Looks like the camber/caster woould be off. But probably because it's not under car and bones aren't positioned Im guessing
  4. metal man
    metal man
    You've got to put it all together,under the car to see what you've really got. I don't know anything about your build,so I can't help a whole lot.
    The camber is built into the axle. Unless the axle is bent, the camber will be right.
  5. harleycontracter
    harleycontracter
    Axle is straight Thank you for the help I didn't think there was a really problem. I'll get it mounted
  6. EVANS and 3 97s
    EVANS and 3 97s
    I may be wrong,but are the king pin retainer holes tapered,or differ in size front to rear?
  7. same both sides , pins can go in either way
  8. tommy
    tommy
    The bolt is ground in a way to wedge in the slot on the king pin. With no king pin in the axle, the bolt will p*** completely through the hole in the axle.
  9. 296 V8
    296 V8
    from Nor~Cal
    Whenever iv checked the camber on a stock axle its been excessive …. like always around 3 degrees positive. :confused:
  10. Fogger
    Fogger
    Like 296V8 said stock '32 axles have 2 to 3 degrees positive camber. Put the car together with the engine weight and check camber and caster. Both can be adjusted by bending the axle cold.
  11. harleycontracter
    harleycontracter
  12. neverdun
    neverdun
    Sounds like a tech week article in there. How do you bend the axle cold?
    thanks
  13. U-235
    U-235
    Now wait a minute.....if the axel has 3 degrees built into it (and we are to ***ume to the back)...wouldn't turning it around make it 3 degrees to the front...? or am I just goofy ?
  14. Fenders
    Fenders
    Camber....... not caster.
  15. 296 V8
    296 V8
    from Nor~Cal
