32 ford Clutch/brake pedal setup
Discussion in 'The Hokey Ass Message Board' started by steve185, Mar 11, 2013.
  1. steve185
    steve185
    I am making a HotRod out of a basket case 32 Five window coupe. Has anyone here ever Hotrodded a 32 Ford?
    Really what I need is some direction on the brake/clutch pedal set up. I am trying to do everything from scratch without buying too much stuff. I paln on using manual brakes, my trans is a toploader which has linkage.
    Any thoughts or things to watch out for?
    Thanks
    Steve
  2. VoodooTwin
    VoodooTwin
    from Noo Yawk
    No one here has ever hotrodded a 32 Ford. You are a true trail blazer! :p
    Timing is everything; check out the April edition of Rod & Custom. The HAMB's very own Elpolacko is featured, with his wicked cool X-member kit, and pedal kit for 32 Fords. It starts on page 62. A must read for you lucky 32 Ford guys.
    Also search for Harv117's thread on pedal setups.
  3. steve185
    steve185
  4. cuznbrucie
    cuznbrucie
    Oh, my........
  5. steve185
    steve185
    I asked her, but she didn't know anything about clutch pedals
  6. HOTRODPRIMER
    HOTRODPRIMER
    How novel,,someone building a hot rod 32,,,What a revolutionary idea!:D
    If you don't have the pedal setup 35 to 40 Ford will work. HRP
  7. Nobody really Hot Rods '32 Fords,
    they only built them for one year, they really didn't catch on
    like Henry hoped
  8. Are you using the original K member?
    Charlie Stephens
  9. steve185
    steve185
    [QUOTENobody really Hot Rods '32 Fords,
    like Henry hoped ][/QUOTE]
    That's what i thought, I am thinking of lowering the roof as well. Kind of like chopping it off.
  10. VoodooTwin
    VoodooTwin
    from Noo Yawk
    That's what i thought, I am thinking of lowering the roof as well. Kind of like chopping it off.[/QUOTE]
    Hooligan! :p
  11. steve185
    steve185
    I have the original K member and pedals, but was not planning on using them. I found a mounting kit from Paul Hortons Welder Series I may order, the price is quite reasonable.
  12. Crazy talk I tell ya'
    Look forward to seeing a build thread on it.
  13. Deuce Roadster
    Deuce Roadster
  14. Fortunateson
    Fortunateson
    Since you have the original pedal ***embly you can modify the brake pedal by cutting the tab off where the pedal attaches to the linkage and then welding it at 180 degrees to the orinal position. Idea from Vern Tardel in a book "Building an AV8" by Mike ishop I believe. This only applies if you're going to use the original K member...go flathead!
