Hot Rods 32 Ford door handles
Discussion in 'The Hokey Ass Message Board' started by 32highboy54, Jan 10, 2014.
  1. 32highboy54
    32highboy54
    from southport
    I just pickup some door handles for my 32 Ford 3 window My question is the base plate for the door handle. Most pictures I see the base plate is vertical. When I put the handle on I liked the look with the base plate horizontal . It flows better with the belt line.Does it make a difference?
  2. lowsquire
    lowsquire
    from Austin, TX
    Original doors have a little insert piece inside the door skin with two fine threaded holes for vertical mounting. As you are asking I ***ume your doors dont have this.
    operationally it wouldnt matter if you put them horizontal.
  3. HOTRODPRIMER
    HOTRODPRIMER
    Gl*** body..This was what Randy posted back in 2012 but his was a original Henry,with your car being gl*** if you like it turned sideways it's really not going to matter,,your car,make yourself happy. HRP
  4. Fogger
    Fogger
    Hard to improve on the original Ford design! But it's your choice.
