first of all, i have searched several times and cannot find an answer to this. is there anyone on here that sells stamped 32 rails? if not who do you reccomend to get them from? thanks for any help, jeff.
As TMAN suggests, try those alliance vendors. Also, go ahead and get an Alliance membership, I think they have a good discount on those items, makes it even nicer!
if you cant find on the hamb, ( vendors ) try speedway motors or american stamping company ( ascrails.com/ )
Give Eric a call,,,,,,HRP 1-800-530-7636 1932 FRAME RAILS BACK TO MAIN FRAMES & RAILS <TABLE cellSpacing=0 cellPadding=0 width="100%" border=0><TBODY><TR><TD style="WIDTH: 484px; HEIGHT: 300px" vAlign=top> <TABLE id=Table1 cellSpacing=0 cellPadding=5 width=550 border=0><TBODY><TR><TD vAlign=top align=middle>1932 Ford frame rails </TD></TR><TR><TD vAlign=top align=middle> [FONT=Arial, Helvetica, sans-serif]Die stamped 10 gauge steel.Stamped in rear C notch for axleclearence Great detail in the side rail,all body mount[/FONT] [FONT=Arial, Helvetica, sans-serif]holes in stock location. The perfect foundation for your deuce chassis. Only $695.00 pair Full length boxing plates $135.00 pair.[/FONT] [FONT=Arial, Helvetica, sans-serif]Other parts to consider; Polished stainless spreader bars,$55.00 front , $85.00 rear Model A front crossmember for unboxed chassis $85.00 Super low front crossmember for boxed rails $99.95 (must use radiator with flat bottom tank) Don't forget your adhesive frame welting $24.00 20' roll[/FONT]</TD></TR></TBODY></TABLE></TD></TR></TBODY></TABLE> <TABLE id=Table1 cellSpacing=0 cellPadding=5 width=550 border=0><TBODY><TR><TD vAlign=top align=middle>1932 Ford "K" member </TD></TR><TR><TD vAlign=top align=middle> [FONT=Arial, Helvetica, sans-serif]Building a flathead power car?This K member is the main component needed.(shown sitting loose in frame) $455.00[/FONT] [*][FONT=Arial, Helvetica, sans-serif]Better pictures soon.Ask me about 32 pedals and trans mounts.[/FONT] <TABLE id=Table1 cellSpacing=0 cellPadding=5 width=550 border=0><TBODY><TR><TD vAlign=top align=middle>Misc.frame stuff </TD></TR><TR><TD vAlign=top align=middle> [FONT=Arial, Helvetica, sans-serif]CE center X-member 1934 Channel style with trans mount $275.00 Tubular X-member,lots of options here various manufacturers and style[/FONT] [FONT=Arial, Helvetica, sans-serif]Buggy spring rear crossmember ('40 spring) $215.00 Rear ladder bar crossmember $72.50 (pictured) [/FONT][FONT=Arial, Helvetica, sans-serif]Engine mounts,pedal kits,everything to finish your chassis. [/FONT]</TD></TR></TBODY></TABLE> </TD></TR></TBODY></TABLE> [FONT=Arial Black, Gadget, sans-serif][FONT=Arial Black, Gadget, sans-serif]rileyauto@comcast.netnet[/FONT] 1-800-530-7636[/FONT] <!-- Content:End --><!-- /sf_content --><!-- 12 -->
