Technical 32 Ford grille dimensions
Discussion in 'The Hokey Ass Message Board' started by jeffgies, Sep 1, 2024.
  1. jeffgies
    jeffgies
    Would anyone be able to do a quick measurement of a Deuce grille for me? I'd like the width (left to right, are the bars round?) of the grille bars as well as the space between the bars.
    Thanks
  2. Fordors
    Fordors
    The grille sides are not parallel and the dimensions shown in the photo will be minus an eight of an inch as there is a small lip where the grille rests against the shell. The bars are .110, formed from 23 ga. (.027) sheet stock on a press brake.
    All dimensions were taken from a Dale’s Manufacturing reproduction grille. The Dale’s is no longer available.
    Just Gary and jeffgies like this.
  3. jeffgies
    jeffgies
    Thanks a lot for these details. Can you also tell me the distance between the bars?
  4. Happydaze
    Happydaze
    On my Dales grill they're spaced at 0.25".
    By contrast, on a Vintique the bars are slightly narrower and the gaps slightly wider. Not really different so as to be noticeable.
    I understand the Dales is a faithful reproduction. I no longer have a stock ford one to check that against.
    Chris
    Fordors and jeffgies like this.
  5. jeffgies
    jeffgies
  6. goldmountain
    goldmountain
    There are 43 grille bars. Easy to remember - Richard Petty number.
  7. Ned Ludd
    Ned Ludd
    If you have any CAD software I've got an AutoCAD drawing, done from measurements from an actual shell. I can send you .dwg or .dxf; metric or Imperial.
  8. jeffgies
    jeffgies
    I can make use of any CAD file you’re able to provide. The plan is to fab a 32-like grille for a Model A with an extended grille shell
    Ned Ludd likes this.
  9. Ned Ludd
    Ned Ludd
    I've just PMed you.
