Technical 32 ford headlight bar
Discussion in 'Traditional Hot Rods' started by 29 coupe, Jul 9, 2022.
  1. 29 coupe
    29 coupe
    Could someone tell e the length of a 32 ford headlight bar is it shorter than a model a one
  2. 19Eddy30
    19Eddy30
    from VA
    There are different lengths, a search will tell you, I Believe 28-29 , 30-31 then a 32
  3. Just measured my stock 32 bar. I measured the underside following the curve from where the bar meets the mounting to where the bar meets the opposite mount. 40-1/2 inches.
  4. Deuce Daddy Don
    Deuce Daddy Don
  5. Deuce Daddy Don
    Deuce Daddy Don
    Here's what I did-----Took a crashed stock bar ---cut the ends off about 4 inches from flange mount.
    took my old stock bar & traced it on floor with soapstone to get the correct arch. heated 3/4 round stock steel to match the arch, then heat & bend remainder up to meet the flanges, then welded headlight mounts to bar, grinded all welds & had it chromed.--------Don
  6. 29 coupe
    29 coupe
    Could you give me a measurement from the top of the mounting flange to top of other side flange
  7. 19Eddy30
    19Eddy30
    from VA
    Yes 32 shorter
    Model A 30-31 is
    43 across top
    38-3/4 across bottom
    32 bar is 42 top
    37-1/2 bottom
