32 Ford info
Discussion in 'The Hokey Ass Message Board' started by Rich Rogers, Nov 7, 2006.
  1. mpls|cafe|racer
    mpls|cafe|racer
    ... get used to it. You're on the biggest forum there is for people who know a lot about these cars based on what they've read, not because they grew up around them. :rolleyes: Need proof? Check any post where someone needs tech info! haha You'll see people repeated incorrect information that they read somewhere posted by Joe Schmoe who thought he heard a dude tell him once at the bar after 15 beers that "yadda yadda yadda"...
    (Yes, that's a jab. How many of the members of this forum were around and had a rod in days gone past? Not many percentage wise I'd guess...)
    As aformentioned, its your car, do what you want with it.
    Don't listen to anyone else.
    Good luck on the build! :D
  2. mpls|cafe|racer
    mpls|cafe|racer
    Couldn't agree more.
    I'd rather have my 34' pickup cab and box than a 3w body any day of the week.
    (You 3w guys can huff about how I'm just saying that all you want, but I don't give two rats ****s. :D)
  3. MIKE-3137
    MIKE-3137
    I still don't know what it is, how about a side shot instead of the teaser shots? that rear shot looks 33-34ish if its a ford.
  4. Royalshifter
    Royalshifter
    Moderator
    This whole thread is staged.
  5. Rich Rogers
    Rich Rogers
    WTFyou talkin about??
  6. Harrison
    Harrison
    You guys are all crazy.
    Don't you recognize a '32 Scout when you see one?
    JH
  7. heavytlc
    heavytlc
    You have a 1978 or older FJ40 frame. The vin will be on the outside of the p*** side front frame horn. It will start with FJ40****. It has been bobbed at the back. The center crossmember has been cut out also. It is a heavy turd for a hotrod frame. They are good frames, but not under any kind of hotrod.
    To be nice, the best thing you could do is throw the frame away. ModelA, repop 32, 2x4 square tube, **** it pine 2x4's would make better frame rails.
  8. MIKE-3137
    MIKE-3137
    So, its a '32 Landcruiser then, cool.:D
  9. TimDavis
    TimDavis
    hahaha
    So it isn't a scout or a Ford?
    Priceless.
  10. mecutem
    mecutem
    About 15 years ago a buddy of mine told me about a 3W he saw in someones front yard on the way back from a fishing trip. I grabbed the trailer and went to see. 32 FORD 3W on a scout ch***is is what it was. Yep..scout rolling ch***is. The car was a case where someone used what they had to make a " RACE CAR". I paid the man $500 and it rolled on my trailer pretty good on that scout frame. Body had a number on the doors, 42 I think, stock dash and rear garnish moulding. I couldn't wait to get it home and LOOSE that scout frame. I was lucky in that nobody modified what was left of the subrails to make it fit the scout frame. A few years later I traded that 3W for a 32 roadster.
    Putting togather a hot rod on the cheap is cool. The phrase "building a Hot Rod" means to me putting togather the best parts to make the most useful, best looking and performing hot rod within your abilities, both $ and skill.
    I commend you on how well you are taking the points, positive or negative made here on this post. Bottom line is do what you want too. Personally I would go with Model A or 32 rails.......not much dough and fit and looks are soooo much better .
    I can give you measurements off my stock 3W i body when you sart ***embly if that helps you any.Steve
  11. Someone didn't come from the shallow end of the gene pool, they came from the damp area beside the gene pool............
  12. Bishop Welding
    Bishop Welding
    from USA
    That's a 32 plymouth.
  13. TimDavis
    TimDavis
    lol - right on..
    I just want full credit for calling Plymouth first in this deal....haha
  14. loudpedal
    loudpedal
    from SLC Utah
    ?????What are you guys talking about?????
    I thought every old car was a 32 Ford.
  15. Bishop Welding
    Bishop Welding
    from USA
    Yeah, or a "woody"
  16. Marko
    Marko
    A few years back I put together a '34 Ford p/u. I started with only a poor cab. Since I planned to channel it, I took a bunch of measurements and after much junkyard looking, used a Nissan truck frame for the BASIC frame. I had planned to use a Dodge double dip tube front axle ( without much drop ), so the Nissan front frame kickup worked out fine, to get the front low. I think the sweeping front kickups ( also they pinch-in nicely ) look much better then starting with a typical ladder frame and "Z-ing" it. I think some of the snide remarks you got was people thinking you were going to do a 4wd version. IMO if you channel the body over the frame, and think about NOT using parallal (sp?) front leaf springs, go either cross spring, 1/4 elliptic (sp?), or coil-overs, the front will be ok. I tip my hat to you for thinking outside the box, and saving the old tin.
  17. "HOTROD"
    "HOTROD"
    from Seattle
  18. TimDavis
    TimDavis
    Kris - my axle looks awesome.
    I'll get a pic up on your thread over there later -
  19. Rich Rogers
    Rich Rogers
    I couldn't help myself, after taking all the comments that were starting to get kinda rude, we did what I said and put the 32 Dodge or Plymouth roof for the pics and while we were at it set a 32 Chevy radiator housing out with it:D But that is the back half of a 32 ford.Hell what'll they say if it's built with those parts instead of any right ones beside the shell itself?:rolleyes: :D
  20. alchemy
    alchemy
    Ha, Ha, you're funny. But that ain't no 32 Ford back half either. Awww.
  21. Zombie Hot Rod
    Zombie Hot Rod
    from New York
    Any info on the progress of this?
  22. Rich Rogers
    Rich Rogers
    No not really, there has been so much bashing along with actual help on this that it kinda led to mixing parts for pics. Now I'm getting things like it isn't a ford at all. What we did was take the rear of the ford,roof of a 32 Dodge and radiator shell of a 32 Chevy along with the frame which turned out to be I guess from a J40 Landcruiser or something like that.Anyway the whole thing just kinda went stupid.We're gonna build it anyway
  23. MIKE-3137
    MIKE-3137
    why not a pic of the real parts, like you said?
  24. whats really funny is if you look at pics from back in the day the duece 3 window was not the holy grail of hot rodding in fact alot of dueces were tore off there frames for model A's ?? and the dueces and other b models 33 and 34's were used as roundy round crash up racers..now that they are rare cause they were used as junk like 80's camero's so much.. the 32 guys are born cause they are much more RARE than a model A..I do agree with these guys ...what ever you have can probably be sold to build a really *****en complete car like the car for under 5k post has pics of... I sold a 34 3 window like you are describing last yr for 6k and wish i hadnt at this point I could hardly find another at that price.. the point is you holy grail guys are all ego maniacs and its a shame just offer the guy some cash or a trade for his parts
  25. Hackerbilt
    Hackerbilt
    Well...that cuts right thru the ********!!! hahaha
    I really don't think the guy has much in desirable 32 parts...but he does have a desire to build a cool, respectable car for cheap. Thats good enough for me.
    BTW...I don't think he ever said he was building a 4X4!!! Not sure how people came up with that. The FJ 40 frame has nice lines even if its a little heavier than needed. Doubt it matters if the frame is slightly heavier than 2x4 tube anyway...
  26. yeah bill you are right LOL any body got pics of the spencer 3 window or the vic 3 window LOL
  27. Royalshifter
    Royalshifter
    Moderator
    Build it SAFE drive it and have fun.
  28. Rich Rogers
    Rich Rogers
    That was the plan from the start:) Just needed some dimensions to help and all the other stuff got started that dragged this post WAY out of proportion. Thanks:D
  29. Ha ha ha!
    Thata what a guy can expect when dealing with folks in a CULT , Rich!....32 folks are a Cult ya know....;) .
  30. mpls|cafe|racer
    mpls|cafe|racer
    Interesting saying from someone who is from a state that is soooo sp****ly populated that the mathematical chances of NOT inbreeding are increadibly small. ;)
    (Just giving you ****. haha I get a kick out of making fun of anyone and anything from S.D. ... not that MN is any better! haha)
