Does anyone know the guy in Ohio who made an adapter kit to bolt a 39 master cylinder to a 32 k-member using stock 32 pedals?
This is the phone number I have for MEC: (330) 644-3450. I called and they still make their mount. I have attached pictures of the master cylinder mount I made for my AVATAR. The original pedals were not modified. I bolted a plate to the rear of the K member using existing holes. I welded a piece of square structural steel to the plate. A steel plate was welded inside the piece of structural steel to mount a ’39 type master cylinder. The structural steel was shaped to support the bearings for a shaft. One lever on the shaft went to the original rod that came through the K member and a second lever went to the master cylinder. The length of the levers was determined by measuring a ’39 pedal ***embly. A hole on the top is used to fill the master cylinder through the hole in the floorboard originally used to check the battery. I mounted the battery on the p***enger side but with smaller modern batteries it could have been done better. Charlie Stephens
