Technical 32 Ford original sending unit in modern tank?
Discussion in 'Traditional Hot Rods' started by 303racer, Jul 5, 2021.
  1. 303racer
    303racer
    Can anyone point me in the right direction to use a original 1932 Ford gas tank sending unit in a modern tank? (I'm using original gauge)
    I Was thinking of using a TANK INC universal fuel tank #U-2A
    I'm not to worried about the mounting issue
    I can weld/fab a retaining plate, I just need to know what I need to do to make it functional
    Any recommendations or first hand experience. Would be appreciated greatly.
  2. Original was 6 volt so you will need a voltage drop if your running 12 V. Original was on a negative ground system .Not sure how that would work if you have gone 12 volt positive.If your still 6 volt neg ground its just a matter of mounting it.The depth of your tank will need to match a 32 tank if you want it to read accurate.
  3. The original sender was hydrostatic. No electric connections involved. If you have a good sending unit it should work in a reproduction tank if you can make an adapter to mount it.
    303racer likes this.
  4. 303racer
    303racer
    Correct it is hydrostatic, I thought the same, put it in and done, but have had a few people telling me it won't read correctly but cannot elaborate why
  5. alchemy
    alchemy
    Is the repro tank deeper or bigger? If no, then I can't see why you would have a problem. If it's deeper you will have a few gallons in reserve after the tank reads empty.
  6. chop&drop
    chop&drop
    The TANKS U-2 is 14 1/2” tall and isn’t full width at the top. A stock ‘32 tank is only 9” tall. You will still have at least half a tank of gas when the original sender registers empty.
  7. chop&drop
    chop&drop
    The U-2 might be a good choice for your application with the right sender but I have no idea how to get one to work with an original gauge.
  8. Mr48chev
  9. You not only have to change the float length, the float pivot needs to be at about half the tank depth.
    Original tank, half height is about 4 1/2". New tank half is about 7 1/4".
  10. alchemy
    alchemy
    Guys, those senders with arm floats don't work on stock '32 fuel gauges. They are a totally different breed of animal.
  11. 303racer likes this.
