Technical 32 ford pickup engine mount?
Discussion in 'The Hokey Ass Message Board' started by tb33anda3rd, Sep 12, 2020.
  1. tb33anda3rd
    tb33anda3rd
    helping @BP32 putting his 32 pickup together and I am not sure what this bracket is. is this the way the 4 cylinder motor is mounted? what is the little bracket for on the side? how should this motor be mounted if this is not the mount?
    the front cross member is not riveted in. is it the right one? IMG_0851.JPG IMG_0852.JPG IMG_0853.JPG
  2. 4ty
    4ty
    Not sure what the bracket your hand is on in 2nd picture, but the two "legs" sit on the biscuits that go on the holes in the crossmember.
    Paul in CT
    tb33anda3rd likes this.
  3. 62pan
    62pan
    Never seen a front mount like that. All mounts I seen bolt to the bottom of the front cover like on an A. There are different lengths and styles depending on year. This is a 32 mount used on an A. Hard to see in photo but it goes from one side to the other over the crank but bolts to the front cover. 20191130_091425.jpg
  4. ct1932ford
    ct1932ford
    Cross member is correct.
  5. GregCT.
    GregCT.
    from CT.
    Some hokey *** member mount. Looks like the vibration damper that mounts to the firewall and then to the back of the motor with some Yankee jury rigging added. Will text a pic later today Ted from the 32 woodie of front and back mounts. I think I have an extra set of each.
    tb33anda3rd and continentaljohn like this.
  6. continentaljohn
    continentaljohn
    Crossmember is right but as said mount is janky
  7. Model A motors were used in all kinds of machinery equipment. Not all were mounted as in a Car/Truck. That even though it may bolt on the Motor is Not for a Car or Truck frame. Whatever you have in your Left hand needs to be set aside into the Whatzit box. Henry didn't slot mount holes till the 60's.
  8. oldtom69
    oldtom69
    from grandin nd
    rare factory 32 Ford factory air-conditioning bracket?
    Bandit Billy and tb33anda3rd like this.
  9. tb33anda3rd
    tb33anda3rd
    the upper two bolts of the bracket line up with the 32 water pump blots. they would not sign up with an A head.
    truck is a basket case with almost no two parts bolted together.
    maybe they sourced the motor from a piece of equipment? compressor/ stationary, etc and this was the bracket that held it on?
    flatford39 likes this.
  10. Kiwi 4d
    Kiwi 4d
    This is what a 32 B4 engine mount looks like on our fairly original (apart fro alternator which is gone now) Early year production pickup. 42159626-7D17-4C32-B046-3C68BCBB4652.jpeg
    flatford39, tb33anda3rd and Budget36 like this.
  11. tb33anda3rd
    tb33anda3rd
    ok that makes more sense, we don't have that bracket but GregCT has one for sale.
  12. tb33anda3rd
    tb33anda3rd
    thanks all for replying!
  13. Ottomotive
    Ottomotive
    from Arkansas
