Technical 32 FORD PITMAN ARM QUESTION
Discussion in 'Traditional Hot Rods' started by bcowanwheels, Oct 9, 2014.
  1. bcowanwheels
    bcowanwheels
    I HAVE A 32 FORD CAR STEERING BOX BUT NO PITMAN ARM. I,AM BUILDING A 50'S TRDITIONAL ROD. DOES ANYBODY KNOW WHO SELLS PITMAN ARMS FOR THESE BOXES ?
    THANKS
    BOB
  2. X38
    X38
    DISABLE YOUR CAPS LOCK!
    28A likes this.
  3. Very much relevant.
    FlatJan likes this.
  4. Sunday driver
    Sunday driver
  5. clem
    clem
    You guys are harsh! Sorry but I don't know of anyone that makes one. Try search, on here or google, or adapt something similar?
  6. cully33
    cully33
    Put a wanted add here on the HAMB and Ford Barn, 1'm sure someone will contact you with one for sale.
  7. bobfrev
    bobfrev
    drop me a note, I should have one sitting on my parts shelf, and will take a look
  8. alchemy
    alchemy
    Any pitman arm from 1932 to 1948, and F-1's through 1952, will fit on the 1932 sector. Some will have the rod end pointing under, and some will point out. Some will have a little different offset or length, but those may be benefits depending on your situation.
  9. bcowanwheels
    bcowanwheels
    AS far as caps,I like alot of old folk have bad eyes as you most likely will have when you get old ! so I type where I can see what I,am doing. so grow up you computer geeks,life isnt perfect. thanks for all the tips guys on the arm I need, your all a good bunch..............
    bob
    Baron, Sunday driver and wbrw32 like this.
  10. F-6Garagerat
    F-6Garagerat
    Yep. Every one I've ever used needed a tweak with the heat to get right.
    Call **** Spadaro, he will get you right.
  11. Atwater Mike
    Atwater Mike
    I'm old now, and wear reading gl***es sometimes...but my wife is younger, gorgeous, and smart; she is 'computer savvied', as she runs a large company.
    Let me share with you all what she taught me about the 'Fine Print'.
    On the lower left of the keyboard, just below the SHIFT key is the CTRL key.
    Depress the CTRL key, and roll the wheel on the mouse. The print will enlarge one way and shrink the other way.
    No need for caps.
    I thought the over reaction about them was 'excessive', but I really lack political correctness.
  12. X38
    X38
    I wear gl***es to use the computer. Plus, you can change the size of the font if you want it larger as Mike says. And that's only one way. When you post a reply, the 5th icon from the left in the reply box is for altering font size. Works like this!
  13. Elrod
    Elrod
    Henry Ford made them. He made them stronger than any **** you can buy today. Source original parts and make it work!
  14. dan@larescorp
    dan@larescorp
  15. gwhite
    gwhite
    SUPER MODERATOR
    Do you need the p***enger arm or the commercial? They are 'clocked' differently to account for the slightly more vertical orientation of the commercial column - nothing a file can't fix, but there is a difference. Another option is the 33-34 arm, but it has the built in ball; good luck finding one that isn't worn out!
    I bought a NOS commercial arm from Dennis Carpenter a few weeks ago. Call them - ask for the NOS parts department. Part # is B-3590 for the p***enger arm; B-3590-B or BR for the commercial. 33-34 arm is 40-3590.
  16. alchemy
    alchemy
    It's a proven fact that upper and lower case type is easier to read than all upper case. So all the old timers are fooling themselves when they type in all caps "because it's easier to read".
    X38 likes this.
  17. Andy
    Andy
    You can use a wide variety of later arms if you do a little work. You need to remove the blocking splines so the arm can be rotated 45* from stock. Only the 32 and 33-34 arms have the right spline orintation stock.
  18. bcowanwheels
    bcowanwheels
    well, went to the shop today and looked closer at my steering box. what i thought was a 32 box to my knoledge now is a 48-52 f-1 sector box. gosh i was hoping it was a 32 box. i got it so long ago I cant remember when. anyway will it work in my 32 hot rod project ? thanks for all the help.
    bob
  19. jseery
    jseery
    from Wichita KS
    The 32 boxes are not very good (steering wise) and were often upgraded to the F1 boxes. The F1 is considered far superior, if you don't want the F1 box I am sure it would be easy to find someone that would be willing to trade you out. Good F1 boxes are selling for around $150 and easy to sell, so you could also price a 32 box and see if that would be a way to go.
  20. bcowanwheels
    bcowanwheels
    ok so if i use the 48-52 f1 box what would be the best pitman arm to use with it in my 32 ch***is ?
  21. jseery
    jseery
    from Wichita KS
    Not sure there is a "bolt-on" one, the one I am using has to be modified. There are four flats inside of the arm that indexes it and they are in the wrong position. So, you have the file them to the shape of the other splines. I am working on one right now. Not sure of the year/model, I can head out to the garage and take a photo and look for ID marks. Also, somewhat depends on what you are using for a draglink, I'm using the later tie rod ends with the taper.
  22. F-6Garagerat
    F-6Garagerat
    Not sure about a 32 frame but, I have an AV8 with an F1 box and a 36 pitman arm. Had to file out the 4 clocking teeth so I could get it where I needed it.
  23. bcowanwheels
    bcowanwheels
    Yes I want the later "tapered" tie rod ends for my 32 project. getting those indexing slots filed isnt a problem. all help is appreciated
    bob
  24. jseery
    jseery
    from Wichita KS
    If it is an F1 box (and a lot of the earlier boxes) the shaft splines should look like the ones in the 1st photo, believe the F100 shaft is different, but not sure. The second one is with the flats filed down. The third is the whole setup and the last one is the part number. My part number is for a 39 arm, believe several different years will work (like F-6Garagerat is using a 36), the big issue is to make sure it has the correct connection for the drag link you intend to use. The part number on mine is 78-3590, ***ume you know that the -3590 id's it as a steering arm and the 78 id's the year it was first introduced. Saw some on e-bay for around $25 to $35, one was a mercury which I ***ume would be the same.
  25. bcowanwheels
    bcowanwheels
    YES,my box has the same splines so its a f1 box for sure. did the 39 arm come factory with the taper ? do you have a part number for the tie rod end also ?
  26. jseery
    jseery
    from Wichita KS
    Yes on the taper, both the splined end and the smooth end have a taper (7 degrees on the smooth end). The tie rod ends are the same for many years of Fords someone like Speedway, Summit or Jegs would carry them (or any early Ford supply house).
    Looked up the original Ford part numbers: RH 11A-3270 (used 35-48 Car & 35-64 Pickup) & LH 11A-3271 (used 35-59 Car & 35-64 Pickup). Think they are 11/16-18 on the threaded part and 7 degrees taper on the stud. These are the ends that go into the spindle arms on the 35 up cars & pickups. They use a RH & LH thread so you can twist the tie rod to adjust the toe-in/toe-out. These same ends and a similar rod can be used as a draglink. They could be RH & LH or both the same according to how you want to set it up and adjust it. If they are RH/LH you can just twist the draglink to make it longer or shorter. If they are both the same, you have to disconnect one end the adjust the length.
  27. bcowanwheels
    bcowanwheels
    OK,found a 36 ford pitman arm online for 35.00 + shipping and bought it. 37-40 arms seems like they dont exhist !!! go figure. anyway in order to use this box in my 32 frame i understand i need a wedge piece that goes between the box mounting flange and the frame rail correct ? i know they sell them at places online but there 90.00. i can get my machineist to make me one as its a simple deal 3 mounting bolt holes,1 large hole for sector shaft and then the machined wedge. anybody got the measurements for this ?
  28. jseery
    jseery
    from Wichita KS
    That's one of many ways to solve the problem. I don't have the measurements because I don't like that approach. Nothing technically wrong with it, just not what I like. I want my car (33 5 window) to look like I would have built it in the 50s. You can modify the frame or use a wedge or modify the end of the steering box. Should be able to find some information by searching the HAMB on this one. On the modified box, the end is cut off and re-welded at the proper angle. The angle of the wedge should be whatever it takes to straighten the box up. Bolt the column where you want it and see what the gap is between the frame and the forward edge of the box. Then determine what you need to support it (might make a wooden or something mock-up for a pattern).
