32 ford pu firewall???
Discussion in 'The Hokey Ass Message Board' started by momentumfoto, Jun 15, 2004.
  1. momentumfoto
    momentumfoto
    from Yes
    I need to know if a 32 Ford truck and a 32 Ford sedan have the same firewall. I have a******en firewall that does not seem to fit on my truck... says 32 sedan on the box. I also need the contat info for******en if someone has it. Thanks for the help in advance, Blake
  2. Mild Mitch
    Mild Mitch
    '32 Ford firewalls should be the same for PU or Car.
    Perhaps******in's is off. '33 and '34 Ford PU are both different if I recall.
  3. Yes the car and Pickup as well as all other 32 models share the same firewall.
  4. Deuce Rails
    Deuce Rails
    Where doesn't it fit? Why doesn't it fit? Does it have the "feet" attached? Which side are you pointing to the front of the car?
  5. momentumfoto
    momentumfoto
    from Yes
    I'll go set it in it's place and shoot some pics for you to see the gap... it's pretty far off.
    bp
  6. zonkola
    zonkola
    from NorCal
    Keep in mind that while the '32 trucks used the same firewall as the '32 passenger cars, the '33 & '34 trucks used a completely different firewall that was spot-welded or riveted to the cab (I don't remember which).
  7. FoMoCo_MoFo
    FoMoCo_MoFo
    BP,
    are you goin' to Pomona witgh us on Sat??? Brains will know the answer to your problem! PM ME!
  8. Deuce Rails
    Deuce Rails
    Any luck with the firewall fitting?
    --Matt
