Technical 32 Ford PU window crank upgrade
Discussion in 'The Hokey Ass Message Board' started by A-Bomb, Jan 3, 2026.
  1. A-Bomb
    A-Bomb
    What would be a good (longer) alternative to the little SHORT factory 32 ford PU window cranks. They have no leverage and the new gl*** and felts are a little tight even after lube with dry graphite. Done want any billet aluminum but maybe a later (40 ford PU maybe) one that is a little longer and uses a square shaft regulator and still looks vintage. Thanks
  2. Taboo56Chevy
    Taboo56Chevy
    I think 32/33/34 Ford p***enger car handles are longer than a pickup.
  3. 325w
    325w
    Later models have longer cranks with same size square hole. Did the window regulator get greased real good. And the lower gl*** channel. Might check if the lower channel is dragging on the felt up rights. Gl*** could be off set a bit
  4. HOTRODPRIMER
    HOTRODPRIMER
    A lot of guys use 40 Ford handles.
    I also used them in my '32 sedan. HRP
  5. A-Bomb
    A-Bomb
    Will check that out
  6. A-Bomb
    A-Bomb
    Everything greased, gl*** definitely dragging a little. Everything came in a kit but the felts might be thicker than originals.
  7. A-Bomb
    A-Bomb
    So you just used the set screw against the square to hold them on ? Looks good
  8. A-Bomb
    A-Bomb
  9. A-Bomb
    A-Bomb
    Ecklers has 40 ford window cranks on clearance , 5.10 each. Ordered two for my PU
