Technical 32 Ford rear window garnish moulding dimensions
Discussion in 'Traditional Hot Rods' started by harleycontracter, Nov 3, 2013.
  1. harleycontracter
    harleycontracter
    Finally got to unwrapping the garnish moulding that came with my 5 window project. Can someone measure the depth ,length and height please.The other 4 mouldings look deeper that the rear one. Wonder if it's a model A ? Thanks
  2. krylon32
    krylon32
    from Nebraska
    1. Central Nebraska H.A.M.B.
    If it's real shallow it's probably 2 dr.
  3. harleycontracter
    harleycontracter
    It looks shallow to me compared to the others
  4. xix32
    xix32
    Sedan is 3/4" deep.
    5w coupe is 1 3/8" deep.
    at one time I thought they would be the same, not so.
    A $300. dollar lesson to me !
  5. harleycontracter
    harleycontracter
    Thanks xix32 Looks like I learned something too. What's a sedan one worth ? lol
  6. .
    I have a back window garnish for a 5 window if you need one.
  7. 343w
    343w
    I need one for my tudor if that's what it is, PM me.
  8. harleycontracter
    harleycontracter
  9. Alvis
    Alvis
    Anyone got a rear window garnishing moulding for the 32 Tudor sedan?
  10. sloppy jalopies
    sloppy jalopies
    Tiquer told me that the '31 slant window fordor's rear window garnish will work in a '32...
    didn't tell me what models, but hambers will get you the '31 S/W measurements...
    I know the S/W molding is stamped around the corners and not mounted onto a plate like '28-'30s.
    it looked like a '32 I saw at a swap meet but I had only glanced at it...
    check out the door garnish molding for a S/W fordor and a '32 five window... makes me think the garnish moldings are close, one car has 1 bead along the bottom the other has 2..
    memory says they used funky screw/ nuts...
    HIH.
    29EHV8 likes this.
  11. Hey has anyone confirmed this? Sure would be nice if there was more options eh!
    -Shiny
