Projects 32 Ford rear window - manual or electric??
Discussion in 'The Hokey Ass Message Board' started by cmusser, Feb 2, 2025.
  1. cmusser
    cmusser
    Looking for feedback. I'm building a 32 5-window, original body with a 4" chop. I need all my window hardware and asking for opinions on installing a manual rear "roll-up" window verses installing an electric power regulator, such as a SPW unit. Thanks in advance!
  2. DDDenny
    What would Henry do?
  3. lostone
    lostone
    from kansas
    Not much, he's dead....
  4. My 3 window is getting a power unit
    Vic
  5. pprather
    pprather
    Adjustable from the driver's seat while going down the road adds a lot of convenience.
  6. HOTRODPRIMER
    HOTRODPRIMER
    Manual windows are traditional. HRP
  7. ekimneirbo
    ekimneirbo
    from Brooks Ky
    Wouldn't a manual window require quite a bit of contorting. Wasn't a big deal when younger, but these days I'd rather not.............:)
    chevyfordman, 49ratfink and lostone like this.
  8. Bandit Billy
    Bandit Billy
    Electric but don’t advertise it. No one is ever going to know and no one is ever going to ask.
  9. Hitchhiker
    Hitchhiker
    Yep! Don't ask, don't tell situation.
    49ratfink, lostone and Bandit Billy like this.
  10. RICH B
    RICH B
    I can easily reach and adjust the back window in my '35 from the driver's seat. '32 is a little narrower so that should easy too.
    Guess if I was making it power I would use a Nu-Relics '35-'36 Fordor rear door regulator and gl*** channel. I think the dual arm regulator would work better than a stock single arm regulator or a center lift SPW unit.
  11. Beanscoot
    Beanscoot
    It kind of depends on the rest of the car. If it's got a generator, all drum brakes etc. then manual.
    If it's got an alternator, disc brakes, fancy stereo etc. then electric.
  12. jimmy six
    jimmy six
    Leave the crank handle and do what’s best for you…
    38Chevy454 and maplefrm like this.
  13. deathrowdave
    deathrowdave
    from NKy
    My 3 window is manual , wouldn’t dare have it any other way . As far as adjusting when rolling down the road it can be done from the drivers seat . But , why ? It’s either open or closed weather for me . Power I guess you want to power the windshield also ? Just being a wise *** ! Build it what works best for you and enjoy it
  14. Happydaze
    Happydaze
    I had the same thoughts on my 32 3w but took the lazy route and stayed manual as that's what I had, so less work! I'm happy I did! The window does wind very easily, thankfully! I can roll it down from the driving seat but need to reposition to roll it up. Might be a different scenario if it didn't roll easily! I think that might be the key to it!
    Chris
  15. Ned Ludd
    Ned Ludd
    Manual — but I'd probably put way more thinking into it than it warrants to position the crank where it's easy to operate while driving, without resorting to electrics.
    ekimneirbo likes this.
  16. brady1929
    brady1929
    I agree, manual is traditional.
  17. chevyfordman
    chevyfordman
    I have the manual which goes down easy but not easy to raise and being old makes it tough raising the window.
  18. Xman
    Xman
    Yah, electric, and don't forget the cup holders too.
    partsdawg likes this.
  19. 19Eddy30
    19Eddy30
    from VA
    Mine is manual ,No package tray ,seat 1/2 inch from crank , relocated holes in tracks , not bad up & down ,
    & 70 style cup holder that hangs on door
    Happydaze, Xman and nochop like this.
  20. nochop
    nochop
    from norcal
    Depends on your build style.
  21. Perhaps you are correct. BUT, I can tell you that in the '50s-'60s I would have used electric if I had know about them.
    Ben
