Technical 32 Ford Roadster door handle - angle of the dangle
Discussion in 'The Hokey Ass Message Board' started by SDS, Jul 29, 2023.
  1. SDS
    SDS
    Doing final****embly on my 32 Ford Roadster (Brookville body).
    Noticing things that I didn't notice before I took it all apart to paint.
    The door handles are not parallel with the body lines just above them - they hang too low in the front when in their at-rest state.
    Is there any way to adjust this?
    Thanks~
    hfh likes this.
  2. Is it 90 years of wear-n-tear? If you put your finger under the handle "at rest", can you raise the handle to "parallel with the body lines"? If so, maybe a carb/throttle spring inside the door can take the sloppy lash out like******* in an anniversary cake.
    Fortunateson likes this.
  3. X38
    X38
    Twist the shaft.
    RICH B and da34guy like this.
  4. Petejoe
    Petejoe
    from Zoar, Ohio
    Yep twist the shaft carefully.
  5. Kiwi 4d
    Kiwi 4d
    Yes have done that before ,twist the shaft a little. I****ume by brookville all the internals are new also.
  6. SDS
    SDS
    It is all new...what do you mean by "twist the shaft" ?
    There are 2 set screws in the shaft, do they do anything more than hole the trim piece on?
  7. da34guy
    da34guy
    x 3 Twist the shaft, alittle does alot so be careful
  8. Doublepumper
    Doublepumper
    from WA-OR, USA
    Instead of twisting the shaft to align the drooping handles, I swapped them side to side. They're level now.
    clem and D-Russ like this.
  9. ekimneirbo
    ekimneirbo
    from Brooks Ky
    Can the mounting holes be filed slightly to allow some adjustability ?
  10. SDS
    SDS
    That was the first thing I tried - thanks for the suggestion.
    I think it's the slop in the latch versus misalignment of the handle/shaft.
  11. SDS
    SDS
    Not sure what "holes" you're talking about ???
  12. SDS
    SDS
    Please elaborate on how you accomplish this "twist" operation.
  13. uncle buck
    uncle buck
    What they are saying is that you can put a little twist in the square shaft on the end of it where it goes into the square hole of the latch. This will rotate the handle accordingly
  14. Petejoe
    Petejoe
    from Zoar, Ohio
    Remove the handle with the shaft attached.
    Slide the square shaft into a vise and tighten it in then turn the handle the opposite way of the droop. (Slightly is the key!)
    SDS likes this.
  15. Doublepumper
    Doublepumper
    from WA-OR, USA
    Thinking if you swapped sides and they still sag, the holes in the latch and/or the shafts must be worn. The shaft holes can be brazed or welded to build them up, then filed back to proper size. Same with the shafts. Might be something to look into. Good luck!
  16. RodStRace
    RodStRace
    If the shaft was fine splines, you could align to meet your desired angle. Since they are not, you can twist the square shaft to make the handle rest at a pleasing angle.
    This is a twisted metal bar for decorative iron work, to give you the visual. You do NOT have to twist it this much. I'd also suggest using a wrench to induce twist, not the handle itself.
  17. alchemy
    alchemy
    Maybe the latch pawl isn’t extending out of the latch all the way when the door is closed. That would make the latch think it’s a hair in the open position. Thus the handle is a hair in the open position.
    Cure: thin the notched strike receiver up a bit?
    This would be a good example of why it is important to fully****emble a car to test all components before painting anything.
    hotrodA likes this.
  18. SDS
    SDS
    It's all brand new - Brookville
  19. SDS
    SDS
    I did have it fully****embled, cant say I noticed the handles sagging.
    I'm going for the twist...will post my results.
    Thanks all.
  20. X38
    X38
    Ditto.
    SDS likes this.
  21. 19Eddy30
    19Eddy30
    from VA
    & a little bit of heat
  22. SDS
    SDS
    Not without completely disassembling it- which I'm not going to do at this point. There's a little spring in there that keeps the trim tight. Heat will waste that.
    I'm on operationb "get this thing done and drive it before it gets cold up here in New Hampshire". If the vice and wrench trick doesn't work, I'll save it for this winter.
    Petejoe likes this.
  23. 19Eddy30
    19Eddy30
    from VA
    R&R two screws , pull door handle out ,
    Clamp The shaft in vice or something solid , some heat from hand held butane Map gas , box end wrench & tweak ..
    SDS likes this.
  24. theHIGHLANDER
    theHIGHLANDER
    Does it droop when the door is open?
    I've done the twist gig many times, black marker to show where where it stops in the drive boss.
    SDS and RodStRace like this.
  25. SDS
    SDS
    Oh, so you can remove the shaft from the handle?
    And why are the shafts so long with a threaded hole in the end?
  26. 19Eddy30
    19Eddy30
    from VA
    I can not remember if Originals have threaded hole on end ,
    Unless after market use same square shaft with different Handel,
    On 28-32 ish , shaft is tapped so will not pull out of deck / rumble .
    On 32 door I have had & worked on ,to removed I just pulled the stanchion / belt line trim screws & pulled handle out .
