Hot Rods 32 ford roadster pickup
Discussion in 'The Hokey Ass Message Board' started by falcon2, Dec 7, 2025.
  1. falcon2
    falcon2
    from michigan
    Going to need some help this is probably beyond my ability. Starting on gl*** 32 ford roadster pickup have body repo frame and kugel open wheel stainless suspension kit. Any tips on mounting suspension to frame without frame Jig? Pinching the frame? Wheelbase?
  2. 2deuces64
    2deuces64
    Measure twice, level and make sure your square, then measure again. 106" wheelbase.
  3. redo32
    redo32
    Call Kugel. They are friendly and helpful. If your frame was properly built on a jig it should be good to build on a level garage floor. Like 2deuces64 said measure twice. Kugel should have diagrams for mounting their crossmember. What rear end and suspension? Are you proficient at welding? If not you will be smart to find a local shop with a good reputation that can handle the work.
  4. treb11
    treb11
    When you say "repo frame" do you mean an ***embled, welded , squared bare ch***is or just a set of rails? If it has a front crossmember installed, bolt together the spring and axle and work back to the wishbone or link mounting points.
    If you just have bare rails, a jig or flat surface is needed to properly setup and square the rails. A 32 should not need the frame pinched to use with a 32 body.
  5. uncle buck
    uncle buck
    Also , just a little hint- kugel suspension is a great product, but outside the the focus on this website so don’t be posting pictures of it as it will be deleted
    Just Gary and lurker mick like this.
  6. falcon2
    falcon2
    from michigan
    Thanks for the suggestions so far just collecting parts and getting started
    uncle buck likes this.
  7. uncle buck
    uncle buck
  8. falcon2
    falcon2
    from michigan
  9. falcon2
    falcon2
    from michigan
    Looking to use quick change rear end and wondering about noise factor between a Franklin or new Winters vintage look a like?
  10. krylon32
    krylon32
    from Nebraska
    I've done several, both Kugel & Heidts. It's a very complicated job even for a professional. I strongly suggest you enlist the help of a reliable shop to do the frame. What your doing is expensive. I was in the ch***is business-for 40+ years.and I still had do some careful measuring when doing what your doing.
  11. falcon2
    falcon2
    from michigan
    Thanks I best have someone do the front end installed that knows what there doing. Everything is built around it and hard to change once messed up.
  12. falcon2
    falcon2
    from michigan
    Who is doing the bed sides in metal for the pickup roadster bodys? Seems like lot of options to be had.
  13. Brookville makes them for their version of the cab.
  14. uncle buck
    uncle buck
